diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
BJT subject to hum? - Click HERE for Original Thread
Mr. Triatic
Are Switching-intended BJTs likely to be subject for hum, per a chance?
at least that´s what i suspect, i´ve built a 20W range amplifier in class A, and the delivery with my 'real' BJTs for my project hasn't arrived yet, so, for testing purposes i took a pair of swithing BJTs, (2SC4060) and 'voila' the amp works (woks..), but with a awful hum, i tested at slightly lower bias with regular BJTs and...there was no hum...strange!?.. -or maybe not very strange?
..maybe i have to re-engineer my psu, its a standard non-regulated, 500VA toroidal and a capacitor bank@60,000µF, i do think that should be sufficient...
Circlotron
Hey! I've played with 2SC4060's but only for switching, not linear. Switching BJT's have a relatively poor safe operating area compared to one specifically meant for linear, but they would switch *much faster*. That said, is your amplifier oscillating? Stick a scope on and have a look. Maybe the higher speed capability of the '4060 has upset the stability somewhere?
GP.
Mr. Triatic
No, theres no oscillation...now i have the 'real' Transistors, and it sounds marvelous, no hum at all.
...but i do still wonder why there was hum with the 2SC4060...admit that's strange!?
well, what the heck, now it works anyhow!
Greetings
phase_accurate
Hi Mr. Triatic
I don't have the datasheet of these transistors at hand but could it be that their beta is significantly lower (specially with the bias you are using) than the beta of your "real" transistors ?.
Charles
Mr. Triatic
jep, that might be the case, it would have been fun to really know what was happening there, but what the heck...
Page generated in 0.09674596786499 seconds with 16 queries,
spending 0.05360532 doing MySQL queries and 0.04314065 doing PHP things.
