diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph 3 transformer question - Click HERE for Original Thread
karellen
Hello!
I want to make a pair of aleph 3 monoblocs and all I ve found for the power supplies are 220 va toroids with 2X21 v or 2X15v outputs
the real thing will do with 2X18v ( I guess)
so I must take a compromise; higer voltage with low amperage or the opposite.
any advice will be greatly apreciated!
and merry christmas to all.....;)
MikeW
It depends on your speakers and bias. If you don't need to crank up the volume go with the 15. :D
karellen
thanks, mike
the speakers are 6 Ohms, 89 db
just in the middle of 8 and 4 ohms.....
Mmmmmmm
GRollins
I vote for the 21V, which will give you roughly 28V rails. Then use a CRC(RCRC...) filter on the power supply to drop the voltage along with the ripple. The Aleph circuits aren't overly sensitive about rail voltage, so if you end up with 24 or 27V rails it'll work just fine.
Grey
karellen
Hi Grey
thanks for your valuable opinion ( I`ve a lot respect on you) and
sorry for the delay on responding.... Holidays you know.....
isabido
Karrellen, my english level is very bad.
I make de Aleph 3 or 30, can you write me a email please?
Thanks.
isabido@ibersilva.es
isabido
My transformer is AC 2x24V 500VA,
Have I problem with those 4V of but?
Ideal is AC 2x20 no?
Thanks!
Page generated in 0.021764993667603 seconds with 17 queries,
spending 0.00773931 doing MySQL queries and 0.01402569 doing PHP things.
