diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Optics
Back Fresnel only with 135mm Diam Objective - Click HERE for Original Thread
dracul
I remember playing around with only the short FL fresnel ---LCD---80mm Triplet.
What I noticed was the light passing through the lcd was more even but ofcourse the light cone could not fit withing the common 80mm triplet widely available.
Now, what if we used the 135mm diameter triplet. Does anyone have this gear to test and post the results here?
ancorp
I have a 135mm diameter triplet that looks identical to the one at diylabs. I actually plan on doing some tests with a sharp qa-1000, and page mag, a 500w halogen, a front surface mirror, and that triplet tonight, but cant guarantee...
dracul
acorp,
Is the sharp 1000 a 15 inch lcd. If you dont have a 15 inch lcd use a trasparency that is 15 inch diagonal. It needs to be 15 too test the even light spread of a large object.
ancorp
Actually its a 8.4" lcd I think. I dont have any transperancy sheets.
dracul
Ok. How about this then. Light---Short FL Fresnel---Space Where LCD Would Be----135mm Objective Where it should be
And just check if the beam fits withing the back of the 135mm triplet. Take note of distances afterwards.
Thanks in advance.
hardmen
Dracul (Off Topic)
Where you from in Brazil (because iim Braziliam Too)????
It´s very important to me discuss about DIY Video projectors with a member of my country (because my English is very, very poor)...
Waiting for your reply!!!
Um Abraço...
Maurício Ricci.
dracul
I sent you an email with my contact info. I am in Salvador - Bahia.
I look forward to talking to you about gear and all this other fun stuff.
Page generated in 0.027559995651245 seconds with 16 queries,
spending 0.00574112 doing MySQL queries and 0.02181888 doing PHP things.
Copyright ©1999-2009 diyAudio.com
