diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Curent Vs Voltage amplification in Alephs - Click HERE for Original Thread
AR2
I cannot make up my mind on the problem that I have, so what better place than this forum to ask.
I am sure many people are having the same problem, so I hope we could come with some answers for many of us.
In my three way active system, my bass speakers - sealed Lambda SB12 drivers are not very sensitive – 87dB and are having pretty flat 3 ohm impedance across the range. Upper part is very sensitive and I am able to drive it with very low powered amps.
It doesn’t matter what I do, or how much power I dump into bass units, it just doesn’t drive them well. The power just disappear like in the black hole. I tried several amps, and it is just not what I need. These amps are suffering.
So I concluded that with such a low impedance I need amp that will produce more current especially in the low freq. range. I am thinking of maybe Aleph 1.2 or some Super high powered version of Aleph X. I played with Aleph X calculations, I read all Aleph X and Aleph X high powered treads but I am not sure that I am finding what I need. High powered Aleph fall short in power that I need. Aleph 1.2 seems OK power wise (even more would be fine) but I do not know if it does what I need. I would like to have 200W at 8ohm and 300 - 400W at 4ohm.
Maybe I do not need to hunt for total power, but for Aleph X circuit that is optimized for high current. If that is the case I would like to ask for help in choosing the right values.
Is this a good rout – class A for bass only? Dou you have any other suggestions?
Thank you and Happy Holidays
AR2
GRollins
If you're running a 3 ohm impedance--especially if you intend to play loud--it would be a good idea to go for high bias current. A high powered amp, say 200W, will not do you much good if it current limits into a 3 ohm load. You'll get thin, anemic sound and no dynamics.
You're going to need a very big transformer and lots of heatsinks, and that means money. Start saving your pennies.
Grey
BDP
May I suggest building the A75 if you need to sink some current into a low impedance load. You can get the PCBs and a great construction article. This is the area where I think the A75 outperforms the Aleph and since its for the lower frequency range it shouldn't effect the voicing. On the other hand it might just be the driver that doesn't mate well with your mid. It might be less expensive to try a different driver.
BDP
AR2
I do agree with your comments. Currently I am using Mosfet Class AB 200W in 4 ohm and 400 W in 4 ohm and it does sound anemic. Only after heavy equalization I am able to achieve little bit better results. Amazingly, even Ampeg SVT2 Pro – 300W of tubes in 4 ohms has a hard time driving it.
I have to admit that I am responsible for the aquard match, 86-87dB sensitivity in sealed box, and 101 dB for the mid and 100dB for the ribbon. I was going for high sensitivity in upper end in order to use my 2A3 amp and because I love ribbons. That combination works perfect. On the bottom I was going for the lowest extension I could get in the sealed box. Lambda’s Fs is 23Hz and in the box it is flat until 30Hz. I did achieve all of my goals, and I like the sound...
It is sort of.. late to change speaker now since I already have box and veneering done. As well as sound is great as long as there is something to drive it with. The mid PHL is driven by 18W 2A3 amp and ribbon with Brian’s GC. By the calculation I would roughly need 200W to balance out difference in dB. (Without taking in account load)
If I do not find an amp solution I will eventualy change speaker.
After all my experimenting I am afraid that 75W wouldn’t balance it out with my upper part. I certainly could be wrong because I am judging just on Watts, and not by Amps. I will do some research and reading to learn more about this amp.
quote:
Grey
I already started collecting. I have 48 tightly matched IRF 240s, and Aleph X boards. I now that it will take a lot, but after I'm done I am sure that I will achieve a lot as well as enjoy. I am afraid to do callculations on my own, because I wouldn't be sure that I did everything right. Aleph callculation spread sheet is excellent tool, but I do not have enough experience to be sure that I did all correctly. If you could help me with this or suggest any other path I will appreciate it a lot.
THANK YOU
AR2
This one didn't go trough in the first post.
uli
Keep in mind that for 14 dB difference you need 25 times (!!!) the power to achieve similar output. High efficiency systems like 100dB/1W/1m are not suitable to lo efficiency woofers.
IMHO the cheapest way is to swap that woofer to a more efficient one. Even using a JBL woofer will be less costly that implementing a weird solution for that unsuitable woofer!
Active driving the woofer only in Class A makes no sense, as the benefits of Class A are in the mid hi region. Every well constructed Class A/B will be better for the woofer. I once biamped my system with Aleph2 for midhi and X250 for the lo end as the X amp had a somewhat tighter bass.
Uli
:nod: :nod: :nod:
pro
Can your active crossover increase the bass of 14:bigeyes: dB? It means that for 100mV input of output on mid ans high, it must put out 2,5V on the bass, that it is not a joke. Can it?
uli
quote:
Not quite correct, 25 times the power means 5 times the voltage
14 dB equals 5 times!
Uli
:nod: :nod: :nod:
ingvar ahlberg
Hi
The most obvious solution to Your problems seems to get a better lf driver. The cabinet looks like 50-70 litres, closed or vented?, a Gamma la1231 for instance would make an enourmous difference, same extension 96dB sensitivity, alnico magnet and almost for free , around 100$ in Sweden. If You want to keep present driver maybe the Zen v5 can be a path to try. I use this as amp for my RCF L12P48, better efficiency and further extension but resembling matching disturbances. Also the RCF presents a nicer load to the amp. Running the v5 at 35V rails produces something like 60W at 8 ohms but biased at 2A per output device the subjective impression of power is awesome. When reaching max output voltage swing it ofcourse starts compressing but quite unobtrusive. Have tried to bridge this amp as can be seen in the " power hungry Zen v5 builders" thread. This produced maybe the most powerfull and dynamic bottom end i´ve heard but was almost impossible to get to stay adjusted regarding DC output, will probably require extensive component matching. Also needs balanced input signal. The long nordic winter has settled upon us here so i´ll give it another try.
GRollins
Have you actually measured the woofer, or are you assuming that the simulations were correct? It's quite possible, maybe even probable that the low frequency response is not flat. I don't know about Lambdas, but it's true for Shivas, Titanics, and the like; it takes EQ to get flat low end out of them.
Grey
LineSource
A sealed box woofer should give the best quality transients, so consider more power. Parts Express, for example, has a 500 watts into 4 ohm plate amp for $250, as well as a 1000 watt for $350.
I'm sure your ran many models. A more efficient woofer would have a higher Fs, and hence give up deep bass. OR a more efficient woofer would have lower Qts, and require a port to extend the bass which will compromise transients.
http://www.partsexpress.com/pe/show...tnumber=300-806
"One of the most technologically advanced subwoofer amplifiers on the market!
This new subwoofer amplifier is based on state-of-the-art Class G circuit topology that combines the proven high power, high fidelity characteristics of a Class AB amplifier with a patented tracking down converter power supply to achieve an operating efficiency up to 86%. You get the efficiency of a Class D amplifier without compromising audio quality and reliability. The class AB output stage provides the clean and low-distortion sound that audiophiles demand, without any instability problems of other high-efficiency amplifier designs. This American designed and engineered amplifier uses patented circuitry that continuously tracks the input signal to modulate or control the voltage available to the output stage. This "tracking" capability delivers the exact amount of power based on demand instead of constantly keeping it in reserve, so the output stage only draws the amount of power that is required at any given time. This means less energy is wasted as heat, and more power is available for the subwoofer driver. "
AR2
Just as I went through the design of my speakers all your answers came to my mind. All of the suggestions are great and correct. Let me post some answers to your questions/ suggestions and then we could decide on the path.
I do like mid / high combo a lot and it is a match from haven. Particularly 10” PHL driven by low powered 2A3 amp. After having ribbon I would never go back to conventional tweeter. It is such a great speaker that is not harsh even when driven with SS amp such as GC ( I use to drive it with another tube amp, but it is better with GC)
Lambda is high quality speaker and in sealed box sounds very natural. I chose sealed box over vented because that is my preference – sonically. It is hard to find speaker that is very efficient, has a very low fs and is meant for sealed enclosure. It is usually ether or.
Just like Line Source pointed out and I couldn’t spell it better.
I checked for Gamma la1231, since I am not familiar with that speaker and I couldn’t find much info. It is certainly interesting speaker based on the specs, the only question is if it is constructed with sealed or vented design in mind. 12 incher, 96 dB with 25Hz Fs hopefully in sealed box (as much as I gathered over web) Price is great and the only problem is shipping it from Europe since it is not available here in States. For the price it is worth buying it and placing in the same box.
The reason I am stuck on Lambda is sound quality. It is crossed at 225Hz, and even sounds better when crossed at 300Hz as I tried in few experiments. The box is 78 liters. At those frequencies I still need good and clean amplification. I never tried plate amps, but somehow I trust more brute power and lots of iron/aluminum. I certainly could be wrong but with great amp I am sure my chances are better.
My crossover is based on Burr Brown opamps and it allows –12+6dB adjustment per output. On the top of that I am using DEQ2496 just for the Lambda in order to eq. and to increase the signal about 4 db. After that it goes into class AB Mosfet. With this set up I am able to match Lambdas with the rest, mostly because upper end is driven with low powered amps and because I am amping LF signal before the amp.
I do not like the fact that I have to do so much on the signal, and I would rather put more current from the amp than do what I am doing now. It certainly will be cleaner giving the proper amp to the speaker. If I forget on the matching with Mid/High which so far is working, that speaker needs better amp. That would stand for majority of low extension high quality sealed woofers. Another approach would be designing the cabined with several woofers of the same kind, but that will present us with another problems, such as huge size of the box and difficulties in finding the proper position for ribbon (very limited horizontal dispersion) I think I found a very good compromise for what I like. All that is missing is better amp. Changing the speaker is a solution as well but with another problems introduced.
I measured Lambdas after I built them and based on that I realized that they did very good job up to 30 Hz. I have to admit that my measurement tools are not the best – Behringer mic, and at the time Speaker Workshop in my room – not outside. I am now on Sound Easy. If it helps I could post measurements just have to find them which will take some time, or I will be happy to make new ones. Seeing curves and more than that listening these speakers makes me think that it worth try. As I mentioned I already started collecting parts so I could end up with great amp even if I realized that I should change the speaker. The biggest question is which Uli pointed out: Does class A brings any benefit or should I stick with class AB with lots of current. If that is the case could Aleph X be configured that way?
Thank you all for the great discussion
Stocker
The only benefit of classA over well-implemented AB for high power is to the local electric company when you pay your monthly energy bill! (of course, some will be sure to disagree!
I am another vote for at least trying a different bass driver.
AR2
Here is the measurement that I was able to find. It is unsmoothed close mic measurement in FFT program. I hope you will be able to read it. Not very precise but it is enough to give you idea. This was done without any crossover or EQ in the path, just a row driver.
GRollins
Looks as though the driver gives up any pretense of flat response below about 50Hz. I think your ears are telling you accurately that there's not much bass going on. An amp, regardless of operating class or topology, will not cure this problem. Three options occur to me:
1) EQ
2) Different speaker
3) Live with it
At intervals I drop into threads in the Speaker forum and make myself unpopular by telling people that the Titanics and the Shivas and now presumably the Lambdas are not flat. Not even close. To get anything like deep bass out of them, you have to EQ the critters. At this point, people start arguing with me. Generally, after a day or three of posts telling me what an idiot I am, someone posts a frequency response graph and I'm vindicated. That thread slides into the past, and things go quiet for a month...until someone else comes up and says...
You get the picture.
Just be aware that EQ eats power at a prodigious rate. Godzilla can't sit at the same table as an amplifier dealing with EQ, his appetite ain't big enough; can't run with the big beasts. Don't even think about trying EQ with an amp of less than 100W, and that's for low volume listening.
Now that I'm into the reply thing, I no longer have the graph in front of me, but I think you're looking at a 12dB/oct slope starting at about 50Hz or so. Titanics and Shivas tend more towards 6dB/oct and are easier to deal with. This 12 thing is going to get annoying. There are two ways to approach the problem. One is to start a boost at 50Hz. The fly in the ointment is that this is an invitation to serious instability, so you have to stop the boost and go to at least flat response, if not cut, somewhere in the teens. Your other option is to use a low pass filter with a corner frequency somewhere down in the 15-20Hz range. The declining low pass will combine with the declining driver response to give you flat response from the rolloff up to where the driver flattens out, i.e. around 50Hz, at which point you start rolling off the driver when it gets flat. Draw this out on paper, and it will make more sense.
Passive EQ is out of the question, you're talking active here.
The moral of the story is not to trust the simulations. Just to give the flamers a good place to start, I'll say it again--the Thiele-Small simulations lie. They're a nice starting point, but that's all.
It's going to be up to you to decide what the tradeoffs are. Money? Physical space? Fights with your significant other? The only thing I can promise you is that amplifier power alone will not solve this problem.
Grey
AR2
[QUOTE]Originally posted by GRollins
[B]Looks as though the driver gives up any pretense of flat response below about 50Hz. I think your ears are telling you accurately that there's not much bass going on.
To give some proper credit to Lambdas, as I mentioned it was close mike measure. Proper way would be to combine close mike with 1 meter measure and smooth the responce out 1/3 of octave. That usually lift lower freq. up.
java script:smilie(':D') Sounds like speaker people
Your EQ suggestion describe exactly what I did. I started without it, and it was weak, so I added DEQ 2496. I tried a few combinations and here is one where I pushed it little bit harder. ( See included pict) It is tremendous help. The truth is with all this pushing, Amp does get exhorted as you predicted. Out of my inexperience I was hoping that better amp will eliminate the EQ, thinking that my amp falls short in the low freq. and in combination with difficult speaker just dies out.
Well I have to agree with EQ approach, because something has to level out normal fall off of the sealed speaker. My EQ doesn't support any frequency below 20, so your suggestion on dealing with the teen fq. should be taken care off within the crossover.
So I will take all of your advices:
Keep EQ,
I will certainly try other speaker, at least just to feel the difference. Overall majority of people suggested the very same thing.
And I will certainly live with it, because all considered I like the sound.
That still leave me with one problem to solve. I still need to improve my amp. Even with EQ it easily runs out of power. That 12dB boost sucks out all of the juice and amp obviously suffers. So what amp to chose that will handle this easier?
AR2
Picture didn't go through. Here it is.
pro
In closed box I am using the woofer attached down. In 60 liters it has a -3 db at 70 Hz and then goes down smooth at 12 dB octave. Fs in box is 53 Hz. With the LR equalizer that I use he becamens flat at 30 Hz. The load doesn't go under 7 hom, so it is very easy to drive. Efficiency is about 92 dB, that respect to 86 means that you need 1/4 of the actually power. Works very well until 700 Hz, but I use it at 500 12 dB LR.
Ciao.
GRollins
You can move the test mic around the room and get different curves, but they'll all be variations on the same general theme.
Beware buying other drivers based on simulations--you will likely find yourself no better off than you are now.
Grey
ingvar ahlberg
btw AR2 was a good speaker, not many left unfortunately.
The LA1231 was designed in the early 70´s and is almost identical today, was probably designed for vented designs but works very well in closed systems Qts 0,42; (was used in comercial swedish speaker made of sealed glued marble box of ca 65 litres in the 70´s, actually was pretty good) I´ve heard it in well braced designs, not overly damped, around 75-80 litres and i find it superior to all modern lf drivers with strange conematerials You cant pronunciate. It is almost undestructible regarding power input and has the ,imo, very lifelike soundquality of good quality papercone units. I do not have enough hair on my chest to argue with Grey, but this driver goes subjectively very low in even modest cabinet size.
AR2
quote:
Originally posted by ingvar ahlberg
I do not have enough hair on my chest to argue with Grey, but this driver goes subjectively very low in even modest cabinet size. [/B]
Talking about hair... I feel bold. After lots of experimenting I think that Grey has a valid point. Even with best speakers in sealed cabinet, they roll off in the bottom part. By the T/L specs they have low Fs - in Lambda SB12 case it is 23 Hz, but in real life, that goes up to 30 - 40 Hz. Room adds its own to help (or else). Solution to the problem is as he stated - EQ (with cappable amp); and I would add vented box; or subwoofer. I will choose EQ.
Gamma seems unusuall speaker, low extension and high sensitivity. Price is low, so it makes it certainly attractive at least just to try. This also follows Grey's second suggestion - change the speaker. I do not know what will be the sound but it will certainly help with amp. I would like to check it out but do not know where to find it. Any suggestion is appreciated.
Just to illustrate how far I went with my experimenting, here is the pict of Ampeg tube amp where I added extra capacitors. These caps are beauty of its own, and only output portion of Ampeg is used - six 6550 tubes. I strongly belive that this amp is short on capacitors, but I will agree as well that I went too far. :clown:
AR2
For all suggestions and help I received from you, I feel responsible to give you something back. Today, mornig light was so great and I did a shot of fog setting in. I hope you will enjoy the view as I did.
:cool:
ingvar ahlberg
Well mail me and we´ll work something out, i can buy the units at the best price and as we purchase a LOT of parts from component brokers operating from the states we might find a good transportation method too
AR2
Just did it.
GRollins
I just sold my '74 SVT (silver front--a classic--but I can no longer justify the combined weight of the head and cabinet). I will agree that the capacitance in the amp is light by hi-fi standards, though it is normal for bass amps. For hi-fi use, there's no such thing as too much capacitance, although you might want to put a resistor or inductor in front of the caps to reduce the peak load on the rectifier. For bass (aka "pro") use, you have to watch out for what your cabinet can take--small power supplies are a poor mans' limiter and are purposefully designed that way in order to keep you from blowing your drivers across the room. Proceed with caution; don't say you weren't warned.
The day may yet come when there are reasonably priced drivers that are actually flat, but what we have in the here and now are essentially car woofers repackaged as home units. Hint: Check the response against a typical car sub. They've got huge Xmax, moderate efficiency, and look gnarly as hell, but are limited on the bottom. The parameters can be shifted, of course. Lower efficiency, for instance, would be acceptable to many people, and as monster class D amps increase market penetration, it's likely that we'll see exactly that. The sound quality of those amps we'll leave for another day. For the time being, think of it as an opportunity to learn more about filters--this is known to experienced DIY designers by the more formal phrase,"if life hands you a lemon, make lemonade."
Just be glad these drivers have large Xmax...you're gonna need it.
Grey
AR2
I am still thinking on the amp subject..,
I did few callculations in Aleph X spread sheet, where I changed figure for AC current gain. I did two versions with 66% gain and 80% gain. As a result I got increased power toward lower impedances. There is peak current of 15 or 25 Amps.
Is this calculation correct, or is this possible at all? Would this be the right approach for difficult - low impedance speakers?
AR2
you might want to put a resistor or inductor in front of the caps to reduce the peak load on the rectifier. For bass (aka "pro") use, you have to watch out for what your cabinet can take--small power supplies are a poor mans' limiter and are purposefully designed that way in order to keep you from blowing your drivers across the room. Proceed with caution; don't say you weren't warned.Grey
This was just a test to check if the bass improve with more capacitance. Dealing with this amp is dangerous from any point of view since it is very high voltage. Caps are very big and they do not fit into the case and they will need separate box. Certainly they cannot sit like in the picture. I have two of those Ampegs that I got as present/ trade from Ampeg (St.Louis Music) when I did photography for their brochure and web, so I am not using them in "normal" way combo + head. They are really nice as LF drivers, 2x300W of pure tube sound.
Grey
Thank you Grey for showing me the path. Interestingly I came on my own to many of the similar conclusions, but not being very confident (this is my hobby, not profession)
I always think that I am doing something wrong.
AR2
Page generated in 13.663568019867 seconds with 17 queries,
spending 13.56382942 doing MySQL queries and 0.09973860 doing PHP things.
