diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
ALEPH 2 PCB (ExpressPCB Format) - Click HERE for Original Thread
ppereira
I'm posting a copy of the Aleph 2 PCB that I'm about to start building... If you'd like to view or use the file just change the extension from .pdf to .pcb
You'll need expresspcb which can be downloaded for free from
http://www.expresspcb.com
Anyway feel free to use it if you feel it's any good, and if there's something wrong with it please tell me...
I included a capacitor bank in the main PCB to keep the layout as compact as possible. It's fairly easy to remove it.
Thanks,
ppereira
Here's a picture of the Aleph 5 I just finished:
ppereira
Another one...
ppereira
Changed a few things:
-bypassed zener for the current source with .47uf cap
-the capacitor bank can be installed separately (keeping it on the same PCB brings the cost down) by breaking it off from the main PCB.
-capacitor bank was changed to use Panasonic FC 1800uf/50V caps (or any 16mm diameter caps) for a total of 129,000uf
as before please change the extension from .pdf to .pcb to open it using EXPRESSPCB.
Page generated in 0.053931951522827 seconds with 17 queries,
spending 0.04256010 doing MySQL queries and 0.01137185 doing PHP things.
