diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Please Help with ADCOM GFA-555 II - Click HERE for Original Thread
tman
Hi everyone,
I'm new to this forum and to audio electronics. I just picked up a Adcom GFA-555 II that is in need of repair. I will try to explain the known problems best I can given my limited experience.
Problem: Left channel does not work. Blowing the negative fuse on the left channel. (the fuse that has a "-" above it. Also, when checking the transistors on the power board protected by that fuse my rusults are 19ohms on the top three and 0 ohms on the bottom transistor (labeled Toshiba 2SB554).
Also, a resistor located on the audio board (R114) is giving me a reading of roughly 100ohms. That resistor's mate for the right channel (the side that is working) R164 is reading at 300 ohms.
Just wondering if I'm in the ballpark with this or not as far as figuring out what problem may be causing the left channel to blow fuses.
I would appreciate any comments whatsoever. Thanks for your time,
tim
PS I can post pics if anyone is intersted is seeing the suspected components.
anatech
Hi tman,
Welcome to the forum!
There are other threads on the forum with information on this model. It seems you will be replacing a matched set of outputs and drivers and possibly predrivers. Not a terrible job. Do it right and the unit will last for years to come. You will likely find some burned resistors.
So, take your time and don't buy the cheapest parts. Use On-Semi parts where possible - real ones. There is lots of help here, but do a search and read the previous posts.
-Chris
K-amps
Tim,
I have the original Toshiba replacements for the 555/ 555II. I upgraded many 555's to MJ21195/96's so I have many Toshiba's I pulled out.
Send me a self addressed envelope, I will send you a 554.
Cheers!
K-amps.
PS: Will buy that 555II off you if you don't want to repair it... or even exchange with a working 555. ;-)
anatech
MJ15022 / MJ15023 or MJ15024/MJ15025 will work fine for outputs as well. You must change all the outputs in the bad channel.
-Chris
K-amps
quote:
-Chris
"Must"..... ok I will keep shut. ;-)
tman
Thanks for the info everyone,
I would be more than glad to pay you for the part. Just let me know. By the way, I found this amp which looks brand new for $50 dollars. I hope I can repair it myself but I will keep you in mind if I can't. Part of the reason I'm trying this is to learn more about electronics. The more I read on this forum, the more I realize how much I need to learn. Oh well, guess that is part of the fun of a hoppy.
Thanks,
tim
anatech
Hi K-amps,
Yup, must.
It really isn't worth losing more parts to one transistor that tested okay with a diode test. Over 25 yrs experience to prove this.
Remember, parts are way cheaper than speakers and a tech's time to do it again.
-Chris
K-amps
Anatech,
I use a 100 watt bulb in series... yet to lose an amp on power on.... :D
Happy Holidays.
Hey Tim,
I have roughly 20-30 pairs of original 555 output pairs from Toshiba, let me know how many you want. Email me with details.
tman
Hey Kamp,
I could not retrieve your email.
If you see this message, please email me.
Thanks again,
Tim
K-amps
just emailed u my prodigy email
Page generated in 0.025888919830322 seconds with 17 queries,
spending 0.00585485 doing MySQL queries and 0.02003407 doing PHP things.
Copyright ©1999-2009 diyAudio.com
