| NAP 160 |
| hi i have changed five opamps to AD826AN WICH HAS MADE A MASSIVE DIFFERENCE TO THE SOUND is there any thing else i can do? diodes caps. please help as your coments will warmly accepted thanks john |
| mpopovics |
Hi!
Probably the first what you can do is relative simple.
Check the PS caps, try to use higher quality (Elna, Black Gate)
You can have more attention to digital PS (ok, also for analog).
Those can be the first steps.
Later on you can turn to more difficult modifications (eg. upgrade the clock, add separated transformer and regulator for analog and digital, etc.)
BR,
Milan
PS: I have already mentioned the EIC socket in your other thread |
