diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
829B/3E29 datasheet triodemode - Click HERE for Original Thread
permagne
Hello!
Is there enyone out there who has access to datasheets/loadlines for 3E29 or 829B in triodemode?
reg permagne
Diy martin
Hello,
I can mail them to you if jou want , got them from Peter Millett.
It a xls. file.
Martin.
audiousername
I also have the excel spreadsheet of the curves. I believe they were first prepared by Paul Raymond Leclercq (7N7 on this forum) - credit given where credit's due :).
The curves were made with both sections tied together. Linearity is reasonable.
permagne
Thanks for the reply. This saves the Xmas. Now I can confirm that my workingpoint is where it should be. I run the tube in PSE-mode so the datasheets should be the rigtht ones. G2 max for these tubes are 240V and I have B+ at 320V. Is there some of you who has tried anodevoltage up to 600 in triodemode without breakdown (due to G2max)?
I am looking forward to receiving the spreadsheet.
Thank you very much.
Best regards permagne
Page generated in 0.021384000778198 seconds with 16 queries,
spending 0.00971150 doing MySQL queries and 0.01167250 doing PHP things.
