diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
electrolytic can capacitor - Click HERE for Original Thread
el capitan83
Ok,
Thanks for the replies on the coupling caps, by the way.
I am replacing all of the electrolytics in the PSU. One of these cap cans is NOT wrapped in the PVC jacket, and since the case is grounded, if it were to contact chassis this would give me a ground loop hum, yes?
The reason I ask is because the old units were FP twist lock, and as I could not find a suitable exact replacement, used a clamp for mounting the new unjacketed unit. I believe that the clamp is giving me ground loop hum now.
How should I implement a fiber washer to isolate the cap from the chassis? The FP fibreboard washers available are all too small in diameter.
Other materials, methods of mounting the can clamps, etc?
Thanks again guys
el capitan83
riiiiiight,
ok, then, nylon hardware to mount the clamps-check.
now, to find a washer to isolate the case from the chassis-
the cap is 1 3/8" in diameter, the largest fibreboard washer is this exact size...will it work???
if not, i will have to source some type of teflon/plastic washer, and cut to fit.
markp
quote:
Originally posted by el capitan83
riiiiiight,
Cut a cardboard(not corragated) ring to the size you need. It will work just fine.
el capitan83
...nailed it.
nylon hardware w/ 'surplus' 1 3/8" fibreboard washer.
thanks for all the help, amp is MUCH MUCH MUCH quieter now.
Page generated in 0.030787944793701 seconds with 17 queries,
spending 0.01778841 doing MySQL queries and 0.01299953 doing PHP things.
