| Sweetrobot |
This projector is being sold in working condition but without lens or bulb for $125! 'd buy it just for the panels and boards inside!
http://cgi.ebay.com/ws/eBayISAPI.dl...5149338847&rd=1
I'ma newb, but it may be worth it. if anyone buy it, pls email me at trifonov@tampabay.rr.com . I'm curious as to whether it will work out. :)
May be a worthwhile venture. Much easier to focus an even light through this tiny thing. |
| getafix |
| problem is, I don't think it states if the LCD works only that the LED light works. |
| 18wheeler |
| and many modern projectors won't turn on LCD if there is no lamp. so you cannot reuse the lcd without solving the safety lock first. Unless you are going to buy the lens and the lamp. Then the cost will be much higher. |
| Sweetrobot |
| I have done it in the past. It is quite easy to bypass the lamp. Simply use a resistor equalling the resistance of the coil in lamp and connect the circuit, or simply try closing the circuit- i have done it in oloder epson projecot- this is a worth while venture, trust me. The only ting is, you never know if anything is wrong with the projector other than what is said. Chancer are thats its not. I hope I can find some pics of my old setup using a projector lcd- its very close to real! :) Still, light colour is very important- easy to bleach. |
| Neversaid |
Very important !!
At old projector often a bad ghosting effect appears, i cause that the inline connector of the LCD Panel goes bad.
Please have a look at that too.
Greetings
Bernhard |
