diyAudio.com diyAudio Forums Archive > Top > The Moving Image > LCD
Need info on Kindermann CPD Video - Click HERE for Original Thread
DonnieH
Hi
I recently bought a Kindermann CPD Video LCD projection panel without the power supply or the VGA cable.
Does anyone know the voltage/current rating for the panel and as it has a 26pin LCD connection would an ASK VGA cable do the job.
Thanks in advance
Neversaid
i think it's a OEM of the ASK Impact 400.
We're here in germany (µView) offer those replacement cables for 12.90 Euro + Shipping (UK would be 6.00 Eu).
For powersupply you can use the normal Proxima OVation 820 PS (Pinout on : http://www.virtuel-blue.de/diybeame.../proxsupply.htm
if you're interested so mail me info@nView.de
Bernhard
DonnieH
Hi
Thanks for the response. I managed to get hold of a 12v power supply and an ask cable and it works a treat.
Many thanks :)
alchemist62
I have an ASK Impact 400 and managed to make a cable to run from VGA. According to the manual it has a built in scan converter and will accept composite signals from videos etc, do you know how to make a cable for that input? which pins on the 26 pin plug do the signal and grounds from a composite signal go. Thanks in advance.
Neversaid
Hi alchemist,
take a look into the Manual sheets on www.ask.no, you get figure out there the input (download the manual, ther're the pinouts inside)
Bernhard
Page generated in 0.047441005706787 seconds with 17 queries,
spending 0.00625610 doing MySQL queries and 0.04118490 doing PHP things.
Copyright ©1999-2009 diyAudio.com
