| Opinions on a pair of transformers for a 6 channel gainclone - Click HERE for Original Thread |
| m0tion |
I'm thinking about buy two 21V-0-21V 400VA toriod transformers for my 6 channel gainclone project. I'll be using the BrianGT/PD LM3875 kits. This should produce about 31VDC after rectification. I'd like to get some opinions as to whether two of these transformer will provide enough current for all 6 gainclone and whether 31VDC is too high of a voltage to be using. I plan to connect 3 channels to each toroid. Please refer to the E-Bay link below to find out more about the transformers.
http://cgi.ebay.com/ws/eBayISAPI.dl...item=3859396322 |
| Nuuk |
That's 800VA for 6 channels, so about 130VA per channel.
I always reckon that 80VA/channel is sufficient so you should be fine with 130VA! ;) |
| BlackDog |
| quote: | Originally posted by m0tion
On my 6 channel Brian GT amp, I used 2 x 300VA 18V toroids. There's no shortage of current !!! If anything, I think my voltage may be a little low, so I expect yours would be about right.. |
| m0tion |
Blackdog:
I'd be very interested in hearing some more details about your 6 channel gainclone. Have you already started a thread about it? Pictures would also be great =). |
| BlackDog |
m0tion,
The amp is not 100% finished yet, although it has been in active service for about 6 months now. I was going to take some photos when it was fully complete, but for your sake, I'll try and get the camera out tonight (it's 9am in NZ right now).
Steve |
| kneadle |
Blackdog:
I'd be very interested in hearing some more details about your 6 channel gainclone. Have you already started a thread about it? Pictures would also be great =). | Hear! Hear!
And how are you processing the surround encoding?
Dave |
| BlackDog |
| quote: | Originally posted by kneadle
Hear! Hear!
Dave |
Sorry kneadle, it's just a power amp with volume control. Surround decoding was considered far too time consuming. - I just use the 5.1 outputs on my DVD player.
Steve |
| kneadle |
| Yeah, but that actually makes sense. How do you explain that? |
| BlackDog |
I started a thread about my 6 channel amp.
Steve |
