| sivan_and |
| Wanted PCB's for GC LM3886, anyone from India...? |
| gjo |
Hi Sivan
I'm from Bangalore, maybe I can help. I know of some friends here who have built GCs, though my gear is a bit different.
I note you're from Calicut, I'm originally from Kottayam.
Rgds
George |
| sivan_and |
can i have the contact info of ur friends or Please contact me....sivankls@eth.net or phone: 9387528524
PS: Need PTH PCB's for LM3876 also!!! |
| nitin |
hey sivan,
i 'm also in search of LM3886 pcb and from net i got some search results on making PCB at home using Laser printer, copper clad, photo quality injet printer paper and of course ferric chloride just in 30 min. more on net for detail. But so far i have not taken this approch and want some ready made PCB , a group buy would be better than making yourself.digi01 in this forum selling LM3886 PCB for $4 plus $6 shipping from china not bad.
But if we are able to make PCB layout we can manufg. them in india and group buy can be arranged so the cost will be nominal if manufg. in large no. so that many of us without PCB can complete the amp. at nominal cost. |
| sivan_and |
| GC PCB almost completed.ugliestever found in this site..but electrically seems igood..Thick tracks and a generaous amount of solder on high current tracks.Used Radio shack transfer film + ferric chloride sol.....Wish i had a PTH version..... |
| arasuk |
Hi every one!!!!
I think This Lm3876/3886 pcb is published in Elektor electronics, Quite Excellent and compact Pcb!! Its designed for Both types.
Works better!!.
Arasuk |
| Franz G |
| quote: | | tracks and a generaous amount of solder on high current tracks. |
Hi Sivan
When you don't trust the size of the high current tracks, it is not really good advice to add solder:
Solder has much higher resistance than copper! Better solder a thick copper wire to the high current track, imho.
Greetings to Kerala
Franz |
| peranders |
| quote: | Originally posted by Franz G
Solder has much higher resistance than copper! | Approx. 60/40 tin has 10 times higher resistivity than copper. |
| sivan_and |
I used Glass Epoxy copper clad=Approx thickness=75microns,
High current track width=5mm.
Strictly no solder coating necessary.Current thru DC tracks less than 5Amps.The amp supposed to be used in a brigde config.
In bridge config, supply utilisation is more effeciant,Current is drawn from both rails simulataniously in any instant.... |
| Franz G |
O.K.
Sorry, I misunderstood! Of course, you are on the good side with 75microns/5mm.
A good advice is, to put the bypass caps as near as possible to the chip.
Franz
/Edit: I was not aware, my postings are in the marketplace / group buys and not in the chip amp forum. Sorry! |
| sivan_and |
OK..thanks "Franz G" 4 ur greetings.
In bridge config, supply utilisation is more effeciant,Current is drawn from both rails simultaniously in any instant....
RIGHT ? |
| yusuf |
I am also looking for 3886 pcb. I will be interested in Group buy or if someone has spare PCB.
Thanks |
| syber |
I am also looking for 3886 pcb.I am interested in Group buy.
Thanks |
| Pramod Kumar |
| Can someone please suggest a source in India for PCBs for LM3886 based stereo amplifier? I would not like to order from a source outside India because that would mean paying more for postage than the cost of the PCB. :) |
| sivan_and |
| I agree with Pradeep kumar..me too interested in PCB's..for BPA300 (LM3886 and OPA549) |
| Pramod Kumar |
OK sivan_and, I will let you know if I can find a source for LM3886 PCBs in India.
If there are more people interested in this PCB, then we can get a few PCBs made from some PCB manufacturer in India. It would not be economical to order just one or two PCBs.
However, since, LM3886 IC has been around for quite sometime, so I think there must already be some ready source for these PCBs.
Pramod Kumar |
| Audio.Spec1 |
Hi Guys
I can help you design the PCB Boards for LM3886/OPA549 !....
if anyone is interested, just email me |
| sivan_and |
| Hi ..Audio.Spec1..u've got mail !!! |
| Pramod Kumar |
Hello Audio.Spec1,
I am interested in your offer of help in designing a PCB for LM3886. Being a new member in this forum, I can not e-mail you directly. The forum does not permit me to do so. Please e-mail me at kumarp@vsnl.com. Thank you.
Pramod Kumar |
