diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
My Gain Clone - tribute to Peter Daniel - Click HERE for Original Thread
zygibajt
This is my vision of Gain Clone.This is strictly Peter's Daniel version with Black Gate standard,Riken and Caddock.MUR860 diodes.The transformer comes from local company that produces very high quality transformers for medicine purposes.It has electrostatic and electromagnetic shield and is bathed in epoxy.
All parts are mounted on 2 kg copper bar.I used solid core 99,9999+% continous cast copper for signal path and litz cable made of kynar wire wrap wire for PS.This amp is built as power amp.With a good preamp this is such a nice soundig amp!
Peter did a grat job developing this circuit and selecting components.I tried regualted supply but it didn't quite work for me.
Bartek
zygibajt
side
zygibajt
side/back
zygibajt
back
zygibajt
underneath
zygibajt
front light up - no there will be no blue light!
zygibajt
front open
zygibajt
side open
zygibajt
back open
zygibajt
back open close up
zygibajt
copper bar front
zygibajt
copper bar back
zygibajt
copper bar fron close up
jtbullet
beautiful work. Can you describe your process for machining such nice pieces?
zygibajt
copper bar back close up
kafka
How did you get sa nice chassis?
zygibajt
Thanks..hmm the whole process ,quite complicated...
I designed and built it.
ble0t
Very nice work! Nothing like a good P2P project plus I love the look of polished copper :D
jtbullet
well it's awesome. Can you give us a projected price that it cost to make?
Upupa Epops
Extraordinary careful work, mainly copper heatsink. :cool:
jtbullet
I'm a newbie to this and I'd like to try my hand at it. What do I need, machinery wise, a drill press, and a table saw with a carbide bit(I'll use aluiminum for the chassis)?
Stabist
I believe the finisf is "powder paint"??
Is heatsink bare or lacquered? OK - the first option is better for cooling and the 2nd one will prevent the "oxidation" ...
Otherwise great work - something very similar to my next GC which is still in a process of builidng up ... :D
Vikash
quote:
There's a lot of information here:
http://www.diyaudio.com/forums/show...8200&highlight=
moe29
Zygibajt,
That is one beautiful amp!
Your chasis and point-to-point work is of the highest quality.
It's too bad the lovely insides have to be covered up.
thanks for sharing.
Peter Daniel
Thanks for the tribute ;)
Building a nice p2p circuit is an art and Bartek is a true artist. The attention to detail is extraordinary and placing rectifiers on the opposite side of the chips is a nice touch.
While so many people these days get excited about regulated supplies and snubbers, properly implemented, minimized GC circuit is still the best and in a right system it's really hard to improve on it ;)
neutron7
all i can say is...
:smash: Great work! :smash:
everything is very well thought out and executed. from the clean P2P to the design and metalworking, even those nice bolts you used. some people dont like to see them but if they are nice ones they are good!
is the finish painted, powdercoated, anodized or something else? i cant really see from the pics.
Franz G
quote:
... and placing rectifiers on the opposite side of the chips is a nice touch.
I completely disagree: this is the best way, to get the diodes hot or at least warm.
You need surface and airflow to cool, not just a piece of metal to store energy!
BTW: a very pretty amp! Congratulations.
Franz
karma
nice detail in your work;) gota love p2p
Upupa Epops
To Franz : You don't like warm diodes ? Hot carriers have better sound ;) .
PMA
How about this one?
http://stereophile.com/amplificatio...147/index4.html
:D
Stabist
quote:
Hehe - I must say that after the blue spreaded in almost all projects - it's nice to see green one :D
demogorgon
Very nice indeed..
a bit sceptical of your "heatsink" though.. these litle gc's produce a lot of heat when pushed to their limits, i found out the hard way, and so one would want a heatsink that has a lot of surface areal to maximize air sirkulation and heat dispation.. a commer bar is far from ideal..
(unless you drill it trough and watercoolt the thing :D )
Peter Daniel
I bet that in a regular setup ( no heatsinks on diodes), the diodes will run warmer than a chip on a copper bar.
BTW, the whole chassis here is a heatsink, and copper bar acts as a heat spreader, not a heatsink.
peranders
quote:
Originally posted by demogorgon
Very nice indeed..
Kaffekokarn, the important thing is area, how much and how the surface is.
I'll agree that this bar isn't the most cost effective cooling solution but how hot it gets is very dependent how the amp is used and if not the over temp protection goes on everything is alright.
A real nice job! :nod:
jackinnj
Very nice indeed..
2 C/W to be precise -- you can estimate the heat sink's ratings from the total surface area -- there are two heat sink drawings on National Semi's application note 1192 -- the BPA100 heat sink is 5.375" inches long, 3" wide with 19 fins, each 1" high
zygibajt
Many ,many thanks for all the good words to all of you guys.
I'm glad you like it as I tried to make it as good as I can.
Yes this is powder coating and copper bar is lacquered.
HEAT???
You must be kidding. I used MUR860 without any heatshink at all before and it worked great.Also in my expirence LM3875 needs very little cooling (a small aluminium heatsink is good enough).
This copper bar works excellent! It absorbs all the heat and transfers it to the enclosure. The copper bar barely gets warm after a couple of hours playing loud music and the enclosure gets slightly warm only in copper bar area.In the front it doesn't even get warm.
The amp works just excellent,it is dead quiet (I tied input grounds stright to the main/enclosure ground) and sounds really good.
My next chip project is an ultimate Gain Clone.It will be supplied from batteries and it will have Siemens MKV polypropylene in oil PS cups (the best signal coupling cup I know so far) either 15,30 or 40uF I will try.I will use either solid core copper,continous cast 99,9999% purity or pure silver all around.I wonder how much better the idea of simple GC can be.
All Best
Bartek
Upupa Epops
Bartek, so make this new one like a tube - vacuum caps are ocjective the best, not oil ones :D .
jackinnj
HEAT???
All of the Overture series chips will go into shutdown if they over-heat, or, if the heat sink is under-rated they will cycle on-and-off. That's what the SPIKE system is supposed to do.
I have built a dozen and a half of these amps, inverted, non-inverted, bridged and paralleled -- you can't under-rate the heat sink. National's recommendations -- albeit a bit on the conservative side -- will prevent heartbreak.
Franz G
Bartek:
I like the design and the making of your amp very much!
quote:
HEAT???
O.K.
I am thinking in dimensions from tube amps. When your amp in your configuration does not get hot: Good!
But, for some people, it may be interesting, when I show here an example of a class A tube amp:
This 8 golden cathode resistors permanently dissipate about 30W together.
In a first stage, I mounted them under the chassis, at the aluplate.
The result: the whole amp, the trannies, the caps and the chassis got very hot after about 1 to 2 hours. You could not touch the trannies (>80 degrees celsius).
After, I mounted the resistors on this massive aluplate, 5mm thick, as shown in the foto.
The result: after one hour or two, the chassis and EVERY other part still was <30 degree celsius. But after one hour, the aluplate got more than 80 degrees celsius, the parts inside the amp and the chassis still cool.
After, I attached a heathsink, just 11 fins, to the aluplate.
The result: No problem to touch the heathsink/aluplate: about 40 degrees.
Franz
Upupa Epops
Franz, are this tubes PL 509 ?
jeff mai
quote:
Anecdotal evidence appears to indicate that the chips do not heat up as much with gainclone type designs where the feedback resistor is soldered at the chip pins. Perhaps this explains varying experience.
Although mounted on a fairly conservative heatsink, mine has never seemed above room temperature.
Franz G
Upupa: This are PL519 (running in enhanced triode mode eg. grounded grid) and the circuit is some modified Danielak design (DC-coupled).
Franz
murat
Hi Bartek,
Looks ruely impressive. Simple but elegant.
Beginner question to you: I see 4 resistors in 3875 kit-guide on chipamp.com. But I can see onl 3 in your circuit. Is one of them hidden somewhere? If not, what is your layout? Thanks,
Murat
zygibajt
Halo and many thanks for good words.
This is strictly Peter Daniel"s circuit with 22K Caddock input shunt ,680R Riken and 22K Caddock feedback resistor that is hidden underneath the chip and is soldered stright to the chip pins.In some versions there was also series input resistor but it is not actually needed, at least in my (and not only mine ) expirence.
Bartek
lohk
Hi Bartek,
your amp looks fantastic - I personally like the p2p inside. I love copper, should give myself a push an start working with it for another amp...
BTW: Did you check up my p2p (a little hidden by all those cables though...) on my last documented chipamp? I did use those subminiature carbon resistors, they are a bit smaller than Caddocks and Rikens (like in my last, PD "reference chipamp").
Klaus
Page generated in 0.083833932876587 seconds with 17 queries,
spending 0.01377225 doing MySQL queries and 0.07006168 doing PHP things.
