diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
CDA-9833 xover configuration help - Click HERE for Original Thread
graks
Could need some help on configuring the xover on the Alpine CDA-9833. It is connected to a 4-channel amp. Use the line outputs to the front channels on the amp. The sub-connections on the alpine is connected to the rear channels on the amp. The alpine is set to be 3-way configured. Problem is when i set the xover values corresponding to the speakers frequency range, i dont get any sound from the front mid-tone speakers. I then have sound from the front tweeters and the sub. Anyone have a similiar setup and advice? :)
graks
Seem to be talking to myself here... :/ More info: On the headunits X-over the sound only changes when i change the Hi-band (2-20 Khz) settings. I dont get any canges in the sound when i change the other bands settings. I only get decent sound out of the mid-tone speakers when the Q-band for the Hi-settings is set to 0 (flat). Seems very strange to me... The amplifiers x-over for the front channels is set to flat and the cables are ok.
Page generated in 0.019131898880005 seconds with 16 queries,
spending 0.00906634 doing MySQL queries and 0.01006556 doing PHP things.
