diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Can i paralel the 2 opamps in 5532? - Click HERE for Original Thread
jondoe
Can i use a 5532 but with the opamps in paralel?
I would want to use this circuit
http://www.tnt-audio.com/clinica/dynamicopamp_e.html
but with unity gain and with some easy to find (like the 553*) and inexpensive opamp.
I could use the 5534 but i don't have the tools to compensate it into unity gain (osciloscope etc.).
I tried sometime in the past with 5534 but didn't compensate (or not quite right) and it wouldn't work, it had high dc output & i guess it was oscillating (no surprise here now that i think of it).
Or can i just use a paralel 5532 for a line driver ?
Will there be any problems, load sharing resistors, bias differences ?
Mr. Triatic
there was no page where the link pointed..
well, you can parallell opamps, but there's one important rule and that is to use a resistor in series with the output and after that resistor you can tie the outputs together, those particular resistors makes sure that those opamps feels good and delivers!!
>opamp output >------[4,7ohm]------->connect with other opamp/resistor
it doesn't matter if they're on the same chip or not..
Mr. Triatic
by the way... there was a guy who buildt a poweramplifier using an unholy amount of small opamps.. just parallelling them into one output.. if i remeber correctly there was 44 pcs per channel!!
-i can't remember his homepage, but i'm sure it's out there...
Nicke
Could it be this one?
44 pieces of opamp power amp
jondoe
The link is ok from here.
That's the amp.
I allmost fell from my chair when i first saw it.
I'm not that crazy. I just don't have the finances to buy one of those really hi-end opamps hence this idea.
If you really can't see the page, here is a zip of it.
sivan_and
jondoe!! Pls check the attachment u posted....
jondoe
Am i missing something here ?
I don't see it containing anything obscene...
neither it mentioning something about what i would want, or is it...
Maybe i'm just sloppy...
Or the file is broken,
WHAT is it ???
Pls, enlighten me.
Page generated in 0.026444911956787 seconds with 17 queries,
spending 0.00826478 doing MySQL queries and 0.01818013 doing PHP things.
Please support our sponsor.
