diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Optics
U.S. Precision Len, ie Corning, ie 3m - Click HERE for Original Thread
chiribomb
I looking for info on a lens made by U.S. precision len.
It is a Delta 42 from a Rear projection tv.
I believe it is a f1.0, but if anyone knows where i can access any info on this lens.
it resembles this Delta 265
ancorp
Depends on what ur're looking for... I can tell you that it will only work up to like a 5 or 6 inch source, it has to be placed pretty much right against it... It should be about 100-150mm in diameter... Look around 3m.com... ive seen a pdf document with diagrams and info on some deltas, perhaps that one is there too...
Page generated in 0.013772964477539 seconds with 16 queries,
spending 0.00538445 doing MySQL queries and 0.00838852 doing PHP things.
Copyright ©1999-2009 diyAudio.com
