diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Optics
Can anyone describe this lens please ? - Click HERE for Original Thread
HouseMachine
I bought this objective / lens for $2 lol few months ago... It is projecting the pictures on 5" Psone screen very sharply, however I' m not sure, if it will project 7" Lilliput.
I mean can I get sharp edges when using this objective and 7" screen.
Actually I will try to understand via acetate paper but I don' t have time to find acetate printing paper until weekend. So I need your opinions / inputs ;)
Also, is there any way to understand / find its focal length ? ( there is no info / text on it... )
You can find its dimensions on the attached photos.
HouseMachine
and here is the other photo
HouseMachine
ok guys I think I found some useful info. Mine is probably same with this one;
quote:
BRAUN Ultralit PL 2,8 / 55 mm MC
A wide-angle lens for the projection of miniature format and half-frame slides or for cases where a large projected picture has to be achieved at a short projection distance.
http://www.braun-phototechnik.de/E/...s/objektive.htm
So I am very very very very lol happy. Because I saved some $$
Jolly
IMO, if my calculations are correct, either
this lens has a very wide field angle (in
your case of projecting of 5" Psone screen
it will be at least 96 deg.) or you got its focal wrong.
HouseMachine
thanx jolly for the info, I' m thinking this lens is a bargain :) and it is probably a triplet lens. btw how did you calculate its focal length ? I did a research on google but I couldn' t understand those numbers :p
I don' t understand physics :D
dnsey
The easiest way to (roughly) find the f/l is to take the lens outside and point it at a distant object. Hold a piece of paper, etc. on the other side of the lens, and move it to get a sharp image. The lens to paper distance = f/l, or near enough for our purposes.
Page generated in 0.020917892456055 seconds with 17 queries,
spending 0.00571752 doing MySQL queries and 0.01520038 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
