diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
fast opamps - Click HERE for Original Thread
NAP 160
can any one tell me the single version of the ad 826an opamp as this chip is the best i have heard thanks
planet10
quote:
Can't tell you about that, but i have 2 NAP160s so was attracted to the thread by your handle :^)
dave
morsel
There are many opamps better than the AD826 for audio use, for example: AD8610/20, AD8065/66, AD825, AD843, AD845, OPA627, etc. Of course your mileage may vary. If your supply is less than 24V or ±12V then I would go with the AD8610 for a single opamp for line level use. You didn't say what you were using it for.
Electro
I think AD825 is what you want. It has very close specs as AD826. Go to Questlink or other online IC database sites.
Questlink - http://www.questlink.com/
NAP 160
thanks for your help, im using the chip in my dac the ad 826 an opamp is a lot better than the burr brown opa 2134 ap. so can i convert a surface mount chip to work where the chip it will replace is not a surface mount chip thanks john###########################
BrianGT
Yes, you can use Brown Dog adapters:
Brown Dog SMT adapters
Brian
Page generated in 0.020730972290039 seconds with 17 queries,
spending 0.00687146 doing MySQL queries and 0.01385951 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
