diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
AR ES1 Rega 250 Arm Mounting - Click HERE for Original Thread
tinmanrrtx
I have just purchased a RB250 arm for my AR ES1 TT then I found out that I need almost 3/8 inch elevation between the arm board and the base of the Rega arm. Is this normal and what type of washer you use to make up the thickness? I appreciate any help you can provide. Thanks.
Tin Man
:confused: :confused: :eek:
audio-kraut
Yes, because the rega does not have the adjustment fur height, you either use washers or some kind of available VTA adjusters. There are several on the market, some advertised on ebay.
Kofi Annan
Not that I'm an expert, but heres a link to some Rega tonearm spacers on Needledoctor.
Kofi
lm3
Do you have an ES-1 tonearm for sale?
Page generated in 0.020133018493652 seconds with 17 queries,
spending 0.00658536 doing MySQL queries and 0.01354766 doing PHP things.
