| chipco3434 |
| I have two I frame transformers... 12-0-12/117VAC. Can these be used for a Gainclone or are they a little too small (~17VDC)? Any special wiring with the center tap configuration? |
| neutron7 |
| it should work. supply voltage(min) is 20V (10 + 10) dont expect a lot of power though. |
| grege |
| quote: | Originally posted by chipco3434
I use just one 12-0-12/300VA toriod for testing my LM3875 GCs and found it works surprising well in my system. I'd say give it a go and see how it works with your speakers. |
| chipco3434 |
Good... Thanks for the answers.
Do I just ignore that -0- (zero) tap? |
| ElectroPower |
No! Connect the ground of amp to that value: 0
Cheers |
