diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
moving opamp to Class-A - Click HERE for Original Thread
anli
Hi!
Plenty years ago I have read an article about a moving opamp to Class-A.
The idea is very simple. An opamp's output stage is in Class-AB. We connect
source current between the opamp's output and a negative power suplier voltage.
If signal output current is less than this CS current, only up (npn) transitor works:
it is always open and work in Class-A.
I'd like to know current state of this idea. Especially, I'm interested
in audio listening experience of such trick.
If your amplifier is under designing now, you can try the idea during
few minutes! :-) If an audio signal output is about 1mA and opamps works well
with 10mA output current, the simplest way is to try to connect the opamp
output with negative supplier -15V voltage through 3K resitor.
Andrew
paulb
Hang around www.headwize.com and you will find lots of information on this technique. Or you could search here as well, it's been covered a lot.
Page generated in 0.017673969268799 seconds with 17 queries,
spending 0.00799799 doing MySQL queries and 0.00967598 doing PHP things.
