diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Optics
Would this work (Focus long arc against DXY?) - Click HERE for Original Thread
telemonster
I will run this one by everyone... I'm trying to figure out a way to achive insane light output. There are 1500 and 2000 watt MH bulbs that are long arc, that produce 5600K light.
If I used a 15" MH long arc bulb with some reflector behind it (Salad bowl) and directed the light into a lens that focused the light to a point (think magnyfying glass). This in turn would be focused on the input side of a DXY lens, which in turn would spread the light to a fresnel?
Or is this a case that the light that is focused on the DXY still isn't coming from a uniform source so this non-uniform light entering the lense will just be spread back out by the DXY? Garbage in = garbage out?
I found one bulb that may have a 30mm arc @ 2000 watts, still waiting to hear from the vendor. It's hard to tell the radiation pattern of light and such.
telemonster
Bad news.
2000 watt short-arc lamp isn't availible in US, 120 days lead time, can't use a M134 ballast, and the ballast for the lamp isn't UL listed.
Groan.
Long arc is the only solution outside of MSR-1200 it seems.
Hmmm this isn't that bad of a deal:
http://www.bulbman.com/browseproducts/MSR1200.HTML
$138 for MSR1200...
germanchiwawa
the problem you will see is that it is impossible to focus a long source into a point without specially designed lenses. When you try focusing the source into a point, the "point" will end up being exactly the same size as your arc, assuming you are using normal (generally, spherical) lenses in your light setup.
Page generated in 0.016617059707642 seconds with 17 queries,
spending 0.00487828 doing MySQL queries and 0.01173878 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
