| rabbitz |
Stumbled on this amp case in Australia decided to buy one.
Received it today and not shabby at all........ a very nice unit. Comes with Alps switches, knobs, IEC socket, blue LED and represents great value. Nice to find another supplier as cases are a pain to source when doing amps.
I got them to remove the lettering on the LH top corner which they did sucessfully. BTW, I'm not involved with this site but thought it was a good find.
http://www.diyfidelity.com.au/produ...&products_id=35 |
| Jye |
Great case, thanks for the info.
Is the lettering on the front etched on? |
| rabbitz |
| Lettering silk screened on by the looks of it. They removed the LH top lettering for me with paint thinners and didn't damage the anodised surface. |
| lazyfly |
They're great cases. Factor in the price and they're quite brilliant. Fit and finish is excellent. The base panel is drilled and tapped out for what appears to be a production run of some sort though this shouldn't be a problem for anyone.
Jye, if you get one and want to remove the text some goofy bloke reckons Zippo lighter fluid works as well or better than thinners so you could see it first then remove it if desired.
Cheers. |
