diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Im confused...3 shivas - Click HERE for Original Thread
1needforspeed
Can i run two shivas bridged in 2ohm and one bridged in 4ohm on the same 2ch amp, or can I wire all three bridged at 4 ohm?I was gonna wire all three in parellel but it would be like 1.3ohm and i dont think that amp can handle it.Can anyone give me advice on the best way to wire these? I mostly want all three shivas to be able to reach they're full excursion safely off one amp.
I have an audiobahn a8002t amp.
» 200 watts RMS x 2 at 4 ohms
» 400 watts RMS x 2 at 2 ohms
» 800 watts RMS x 1 at 4 ohms
» 1600 watts RMS x 1 at 2 ohms
» stereo or bridged mono output
* 2ohm stable*
And i have 3 adire shivas.
dual 8ohm voice coils
Pmax 375W per voice coil; 650W total to the driver
Moose
If you wire the voice coils of the drivers in series on each driver, you will get a 16 ohm load per driver, and then wire the three drivers in parallel you will get a 5.33 ohm load. This will mean you will get just under 800 watts from the amp, so around 250 watts per driver. If this doesn't make sense let me know, and I will try and clarify
Mark
1needforspeed
wouldnt i get more power if i just wired them to the amp at 4 ohm?
xstephanx
Id bet too much power. With low frequency drivers these days youll run out of excursion LONG before you run into overheating. 250 watts each should be good, besides you can always change it later.
1needforspeed
okay,i'm slow.i see what you guys are saying now.i wasnt thinking correctly cause i was confused a bit.
1needforspeed
okay,i was thinking a little more...What if i wired one in series and the other two in parellel and then wire all of them together in parellel,wouldnt that be like 2.2 ohms????
Moose
Ummm...not sure how you came up with 2.2 ohms
By my calcs:
1/Zeq = 1/16 + 1/4 +1/4
Therefore Zeq = 1.78 ohms...
even if you did run it like that, the problem is the power is not distributed evenly, and so when you are maxing out you amp at over 1600 watts, you get 711 Watts into the two with their voice coils wired in parallel, and and 177 Watts in the one with the voice coils in series.
I second xstephanx with the excusion problem. I have a shiva for home in a small sealed box with a PE 250 Watt plate amp, and it has no problem making the sub hit its excursion limits.
As a general rule, keep the drivers so they are all seeing the same amount of current, otherwise you are not maximizing the system, as one driver is working harder than the rest.
Hope this helps
Mark
xstephanx
Wow i was right for once. Do you have space for 4? cause adding one more would making wiring WORLDS easier and give a bit mroe output even!
Stuart Easson
This is a job for one channel of the amp driving 1 of each drivers voice coils in parallel, the other channel driving the other 3 voice coils in parallel. Should give more than a couple hundred watts per woofer, with no problems sharing current between the 2 channels. Just make sure you get the phasing of everything correct...
Good luck,
Stuart
1needforspeed
i just wanna thank everybody for their help
Page generated in 0.029681921005249 seconds with 16 queries,
spending 0.01145768 doing MySQL queries and 0.01822424 doing PHP things.
