| Evan Shultz |
I have designed a PCB for the Sorenson 3.0 amplfier. It's a cheap, stripped-down amp but might be fun to try out. Please comment on anything if you have any concerns. If there is interest, I would be more than happy to submit the design and have some boards made.
You can see the schematic at http://listen.to/audioexperiment and click on Archive at the top.
The schematic might be a little bit older than the layout, I can't remember. The board files are top+bottom with planes, top+bottom without planes |
| AGGEMAM |
The real questions are; have you built it? and how does it sound?
The SorensonAmp has to be the most promising class D design I've seen for audio listening in that it doesn't use a clock generator. |
| Evan Shultz |
| Nope, not built yet. I am hoping to make a prototype on cheap PCB soon. |
