diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Working with Acrylic - Click HERE for Original Thread
gilid
Does anyone have any tips for working with Acrylic? I need to cut several pieces that are 10mm thick. Specifically, how to polish the cut edges to a clean smooth finish.
Thanks!
Gilid
wuffwaff
polishing is easy. Use wet sandpaper from coarse (180) to fine (1000) and after that some polishing paste. The last step can also be done with a drill and a polishing "mob?"
William
gmphadte
Use a hack saw used for cutting metal
peranders
quote:
Thanks!
Gilid
It's pretty easy! My acrylic supplier uses a gasol(propane) flame. :redhot: Maybe you can use a hot air gun?
Before you do that the surface must pretty smooth but not extremely.
Selexus
Why not have a look around this site.
www.bit-tech.net
Its dedecated to PC mods. The hot mod being custom acrylic enclosures.
HTH
TwoSpoons
At work we use a LOT of acrylic. Mostly it is laser cut and flame polished.
You could try saw cutting (fine hacksaw), followed by sanding (up to 1000 grit wet paper) then polishing using either a propane flame, brass polish on a rag, or a grinder with a buffing wheel loaded with fine buffing compound.
Page generated in 0.040271997451782 seconds with 17 queries,
spending 0.02651620 doing MySQL queries and 0.01375580 doing PHP things.
