| Danyele82 |
To A75 amplifier for unbalanced use I can remove R28 , R5.
R29 and R2 can be romoved? |
| Danyele82 |
| look here the circuit A75 |
| Alain Dupont |
Danyele82,
Yes, you can...
Well, I don't think so.
For the cost of 4 resistors, 2 XLR's and 2 switches, it's a shame to
remove the Balanced inputs of the A75.!! Who knows, you'll probably
build a balanced preamp sooner or later...
PS: Now with my CCS-X-Bosoz preamp I use my A75 balanced, and I prefer this type of connections, the balanced mode has great advantages...
And using Belden 89207 twinaxial cable, its not so costly to have balanced cables..
Alain. |
| Danyele82 |
For unbalanced use the gain is determinated by (R81 + R3//R27)/(R2//R29)?
If it's right the input resistence (R4) can be eliminated (or it's necessary for the low-pass with C1)?.
The quality of C7 and C5,C6 are important to the final result? |
| Alain Dupont |
Danyele82,
>> If it's right the input resistence (R4) can be eliminated (or it's necessary >> for the low-pass with C1)?.
Keep R4, it wont interfere in the 75 K Ohms unbalanced impedance,
but globaly there must be symetry between positive and negative input's.
Norman Thagard and Nelson Pass tells: the only requirement being that corresponding values on the positive and negative input networks be matched.
For the quality of C3,4,7 4.7uF, 16V, electrolytic
C5,6 220uF, 16V, electrolytic
I have used Panasonics, quite standard types...
Regards.
Alain. |
