diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Help identifing RCA transformer - Click HERE for Original Thread
Tim Wyatt
Could anyone help me find out what this power transformer is and the connections? It is an RCA power transformer. The numbers are:
906158-501 (as far as I can tell)
27465005 4
Thank you for any help you can give.
Tom Bavis
If you don't have a meter, GET ONE. Measure the windings with an ohmmeter. Highest resistance will be highest voltage. Primary is usually in the 10-20 Ohm range, but a large transformer will be less. Once you've identified the primary, connect 120V through a 100 Watt bulb (connect a cord with wire nuts) If the light bulb glows brightly, you have a shorted winding or you guerssed wrong on the primary. CAREFULLY measure secondary voltages - disconnect power, clip your meter on a pair, then plug it in.
Page generated in 0.015938997268677 seconds with 16 queries,
spending 0.00793052 doing MySQL queries and 0.00800848 doing PHP things.
