diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Philbrick metal case op amps - Click HERE for Original Thread
nuppe
Hi there!
I have two old Philbrick Researches op-amps lying around that i'm curious about. One is a P65 and the other is a P45AU. Are these rare? I have no idea, but i have never seen anything like them before. From searching the net, i've gathered they were not meant for audio, but analog computing. I also read that these were among the first mass produced solid state op-amps.
I'm trying to decide wether to keep them or put them up on Ebay or something. If there is little demand, i'll probably stick them in a frame and hang them in the workshop, they are kind of stylish :D.
What do you think, could they be valuable or do they only have sentimental value?
/Andreas
nemestra
Hi Andreas,
the noted analogue guru, Bob Pease, who writes for EDN magazine has written some comments on Philbrick Research op-amps.
See chapter 9 of Analog Circuit Design, edited by Jim Williams, Butterworth Heinemann, ISBN 0-7506-9166-2 (or -0 softcover) where Bob discribes the P2.
James
nuppe
Thanks!
I'll have a look if i can find it around these parts.
Btw, i found a Philbrick manual online, here, havent had time to browse it through yet.
/Andreas
Page generated in 0.019388914108276 seconds with 17 queries,
spending 0.00794697 doing MySQL queries and 0.01144195 doing PHP things.
