diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Alps pot (car audio) - Click HERE for Original Thread
audionutter
Hi guys,
Does anyone know where I can get a replacement Alps pot for my car radio? The original one is shown here, it says Alps on the back panel. The pot controls several functions, push for on-off, pull out for left/right balance control, turn clockwise for volume and also has a fader front/back connected to the outside ring.
The problem with my original one is the centre shaft/pin has broken off and I can't use it anymore :bawling:
So any help is much appreciated! Thanks!
mcs
That is most likely not a standard pot, so buy it as a spare part. It will probably be expensive, but cheaper than buying the minimum quantity from Alps ;)
Best regards,
Mikkel C. Simonsen
Page generated in 0.016063928604126 seconds with 16 queries,
spending 0.00798798 doing MySQL queries and 0.00807595 doing PHP things.
Please support our sponsor.
