diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
3 adire shivas? - Click HERE for Original Thread
1needforspeed
Can anyone tell me about how much db's three shivas will put out if each were in 2.5sqf box tuned to 23 hz
clayton
Well it all depends on how much power you are putting to them. Those are some extremely efficient subs. What is the specs on them?
1needforspeed
I have an audiobahn A8002t.I dont know if i want to bridge all three in 4ohm,or run 2 at 200w and bridge the third in tri-mode and the third will get 400w these will also be 4 ohm.The amp is 2 ohm stable but i dont know if i want to run these with that much power.I you can give me some advise that will be greatly appreciated.But most likely I am gonna bridge all tree @ 4ohm.thanks and please send any suggestions.
clayton
The shiva's can definately handle the power. Just make sure that you set your gains on your amp correctly. The thing that usually blows speakers is distortion. I am not a fan of any audiobaun equipment. To me they are highly overated. An amp that I would recommend is the jbl 600.1 or 1200.1 both are good amps for the money.
1needforspeed
specs on the shiva
Shiva Diameter: 12 1/4
Cutout: 11" Front Mount Height: 3/4"
Front Mount Rear Depth: 5 1/8
Displacement: 3 liters
Re 2.9 ohms
Le 2.12 mH
Qms 6.5
Mms 125 grams
Qes .40
Cms 0.47 mm/N
Qts 0.38
Rms 2.54 N*s/m
Fs 21 Hz
Sd 481 cm^2
Vas 151 liters
BL 11.30
Xmax 16.6mm one way
EBP 51.12
SPL 87.3 dB @ 1W/1m
No 0.37%
Pmax 375W per voice coil; 650W total to the driver
Distortion <3%, 16 Hz - 200 Hz, @ 100 dB SP
clayton
Does your amp have a subsonic filter? This is highly recommended if you are going to port your box. It will help with your bass response @ the tuned frequency.
1needforspeed
No,I don't think the amp has a subsonic filter.If it does its not featured on the box,lol.
1needforspeed
Sorry,I looked in to it more and it has a variable subsonic filter.
Variable Subsonic Filter: 20 Hz - 50 Hz
Now i dont know anything about this, is it safe for me to tinker with?
clayton
Yes you can adj to see the diff it makes. But if you are using a sealed box it will only make it sound worst. Like I stated above it is used for ported boxes. IF say you have your box tuned to 25hz you would set your ssf to 25 hz. You will notice a difference in sound.
Mikett
OK Assuming that you can tune it within a 2.5 cf box Vented, with a large vent ( min 4" dia= 22" long vent ) Assuming that you can get cabin gain starting around 90 Hz or so, you'dk hit about 130 dB at around 26Hz. This is using 300Watts input at which point it is excursion limited around 40Hz.
With three of these connected we probably would hit around 140dB.
1needforspeed
hmmm......140db I think i could work with that for a while...
1needforspeed
Thanks for the posts guys.
danielkelley10
why are you tuning to 23Hz, a 30-35Hz tune is pleantly low enough in a car. With higher tuning you will gain much more efficiency from the enclosure.
Have the subsonic filter set about 5Hz below tuning, basically when you tune a box by porting it, in effect the driver is running free air below the tuning frequency, the subsonic blocks out all the waves below its set frequency. The steepness of the slow effects where you should position it compared to your box tuning, but between 2-5 Hz should provide adequate protection.
1needforspeed
This is the only way i knew how to tune this particular box
danielkelley10
To tune to ~35Hz, 2.5 Cube box you need 4 inch by 4 inch port 11 inches long
kfr01
Download WinISD pro
The shiva is already entered. You can model the SPL curve for different basic box designs. (Including SPL per a given amount of power and max SPL).
You can adjust the port w/l + box size and see the effect on the SPL curve. It has some problems, but is good for a general idea. Also remember that you'll have some help at the bottom end from cabin gain in a car.
1needforspeed
I tried the winisd pro and i think i just am not a pro cause its seems very inacurate and confusing
Page generated in 0.035298109054565 seconds with 16 queries,
spending 0.00987554 doing MySQL queries and 0.02542257 doing PHP things.
