diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
dumb aleph question - Click HERE for Original Thread
george a
Hi All
Please pardon my ignorance ...
If one uses an aleph in unbalanced mode (ie: say one of active pins on input shorted to ground) are you effectivley using half the circuit , while the other half lies dormant - generating heat
Blues
with an aleph p you still get balanced output but with an aleph amp you reference the -input to ground and work with just q1 with q2 still receiving the feedback. the output is still unbalanced as this is a single ended output design.
uli
quote:
Originally posted by george a
Hi All
there are no dumb questions, just dumb answers.
the answer is : no!
the complete amp is alive and kicking!
Uli
:nod: :nod: :nod:
arold19
Me too I have a little question...
On the Aleph30 for exemple, why Nelson Pass protect the (neutral) and not the (live) wire ????
wuffwaff
Hi Arold19,
could you be a bit more precise? I donīt understand your question.
William
uli
quote:
quote:
I understand this as the primary fusing.
Its enough to break one of the 2 power lines to interrupt current flowing ;)
dont care which one
Uli
:nod: :nod: :nod:
Page generated in 0.025142908096313 seconds with 17 queries,
spending 0.00960612 doing MySQL queries and 0.01553679 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
