diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Doubling Digital Input : Question - Click HERE for Original Thread
Blue_Max
The DAC I am using now has only one 75 Ohm electrical digital input. But I need two.
Is it okay to fit a Y adaptor and connect two digital sources to it?
tiroth
No. It may work if only one device is turned on, but you are loading the transmission line abnormally and performance will likely be poor.
Blue_Max
What if I make sure that only once source is switched at a time?
PatPet
You could make a transistor switch for them
Blue_Max
How about something simpler like a double-pole, double throw switch?
rfbrw
The Pass D1 [http://www.passlabs.com/downloads/o...ct/d1_servm.pdf] uses relays and the Stax Talent uses 74 series logic. The choice is yours. I'd opt for something that allows me to hot-switch between sources noiselessly.
Jocko Homo
NO! Re-read post #2. (Glad someone has been listening.)
Jocko
jacco vermeulen
quote:
Originally posted by Jocko Homo
NO!Glad someone has been listening.)
I never knew Benito ate cabbage, not that he was so funny.
Blue_Max
Jocko
Oh! Okay. :o
Good thing I asked, innit? :clown:
Page generated in 0.029922962188721 seconds with 17 queries,
spending 0.00983119 doing MySQL queries and 0.02009177 doing PHP things.
