diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
silver mica caps code - Click HERE for Original Thread
tubbytwo
I was given a bag of misc silver mica caps. Going through them to sort I found mostly 43 pF. (Marked 430) Now I know the third number is the number of zeros but I was told on these (CDE & SMI) caps the value is marked as is, ah, no multiplier and is a 430pF. Ok, then why do I also have 181 and 271 that would be 180 and 270....1 being the number of zeros. To double check, I looked at a radio I was supposed to have 100pF caps on, sure enough they were marked SMI 100 and the invoice from AES confirmed I ordered 100s (they don't stock 10s)
Several Google searches show the 3rd number being the multiplier! Can anyone confirm the numbering system.:bigeyes:
markp
The standard is that the third number is the number of zeros, but not everyone complies to the standard! I've found that if the number is followed by pF then it is the actual value of the cap, but not always. '220pF' written on the cap is usually 220 not 22pF.
Apex Jr
Also with mil-spec parts the last number is the multiplier
IE: newer silver mica's CMO5181J is a 180 Pfd at 5%
F = 1% ... G = 2% ... J = 5% ... K = 10% and M = 20%
Steve @ Apex Jr.
Page generated in 0.017802000045776 seconds with 16 queries,
spending 0.00802660 doing MySQL queries and 0.00977540 doing PHP things.
