diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
4-pins pot - I'm lost... - Click HERE for Original Thread
e-manu38
Sorry if this is a dummy question (tried Google + search diyAudio)...
Dismounting a cheap "amp" (crappy thing, only the box, connectors and pots are worthy!) I found the volume pot (dual, marked B100k - nothing else) has twice 4 pins. And all four are connected to the rest of the world...
I attached a quick schematic - not sure it's 100% correct. But mysterious enough to me. I cannot understand how the pot is suposed to work. Is it really a pot, BTW? Could anyone have a hint about what this thing is?
moamps
http://www.angelfire.com/electronic...Amp-Volume.html
Milan
Frank Berry
What you have is a Loudness Compensation pot.
It's a standard 100K audio taper pot with a tap at 50-60% point.
You can use it as a standard audio pot. Just ignore the tap.
e-manu38
Thanks a lot - I got my reply and be much happy! :) :cool: :) :D :D
Page generated in 0.019471883773804 seconds with 17 queries,
spending 0.00785422 doing MySQL queries and 0.01161766 doing PHP things.
