diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Newbie help on 1545 non OS DAC! - Click HERE for Original Thread
Horizons
I'm using this DAC:
http://www.diyparadise.com/dackit/1545dackit.html
and powering it with this 12V battery and charger:
http://www.towerhobbies.com/products/towp1250.html
I have wired the battery and charger to a switch so the battery is either powering the dac or being charged by the charger.
The DAC works and sounds very good but I am getting a low level almost constant crackling noise from the system. I suspect that this noise might be coming in from the digital coax as I am just using a cheap RCA connected to about 8 inches of standard wire to the board. Do these wires need to be short and shielded?
I was going to troubleshoot by first fixing the digital connector and wiring but maybe I should just power it with a 12V adapter and try to remove the battery as the source of noise? Another thought was to add a cap across the battery.
Thanks for any insights.
DonJuan
hi horizons
you got the pcb from me?
anyway, i don't think your batt is a problem.
the low level crackling noise, when does this happen? when playing low bass?
it could be a poor solder joint or just a "bad" tda1545. i realized that even these parts are all tested good, not all of them could be 100% trusted to be good.
write to me personally at tampinyeo at yahoo dot com to discuss this further, if you wish to go offline.
thx!
donjuan
Page generated in 0.019448041915894 seconds with 17 queries,
spending 0.00810337 doing MySQL queries and 0.01134467 doing PHP things.
