| simple 6v6 push-pull schematic ? - Click HERE for Original Thread |
| vlljpior |
| Hi , i want to built a simple push-pull 6v6 power amp. is there a simple schematic ? does somebody have a good one to suggest? |
| DigitalJunkie |
Here's a fairly simple,nice sounding PP 6V6 amp.
http://www.users.qwest.net/~ptaylor...6V6amppage.html
It's an amp from an old console that I rebuilt,and tweaked a bit.I get right about 8W per channel before any real signs of distortion(Forget how much when triode-wired,probably 3-4W),I think it starts clipping at about 10Wpc.The output transformers are sorta small,but it still has some impressive bass response for a smaller amp.
With some larger/better output transformers I would expect it would be pretty nice.. |
| jazz |
Hi there,
Here's another one. It's based upon using the trannies from an old lafayette la224B (8k a-a). It comes from an article in the dutch mag 'audio&techniek'. I believe the author is a member here. |
| jazz |
darn how do i get that jpeg posted! right size, attached it, no show!:smash:
got it, use the edit function:confused: |
| vlljpior |
| You just have to attach the file by clicking on browse, beside of the attach file... the file will be just fine... |
| jim |
I built both the Dutch schematic as posted above as well as one from l'Audiophile which both sound excellent.
You won't be disappointed when build one of these.
Greetz,
Jim |
