diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Source for KSS-210a cable assembly? - Click HERE for Original Thread
r0cket-
So I've tracked down the source of my RCD-950's problems to a bad cable bundle between the KSS-210a pickup and the control board. Anyone know where to get a replacement? I've looked through my Digikey catalog, but it's hard to find exactly the connector in use. On the plus side, both the pickup and the control board use the same connector, so I can't imagine it'd be hard to find a replacement, since the KSS-210a is a fairly popular transport. I just can't figure out where to start searching for the cable. Oddly enough, I have a spare KSS-210a I ripped from a cheap Aiwa boombox, but the cable is nowhere to be found. Any suggestions, or anyone have a spare laying around? This is the cable that connects to the white header on the pickup, though the red one seems to use an otherwise-identical connector.
Page generated in 0.018477916717529 seconds with 16 queries,
spending 0.00949645 doing MySQL queries and 0.00898147 doing PHP things.
