diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Loudspeakers
Measurement mics - Click HERE for Original Thread
bombardon73
What mics are good for loudspeaker measurements.
I need one thats not to expensive, e.g. ECM-8000 Behringer.
Also see this link http://www.speaker-online.de/ (messtechnik)
Some say that this one is pretty good and others say it's crap.
any recommendations?
Hertzschmerz
With the Behringer you get what you pay for. ;)
I'd recommend to get the Sennheiser KE 4-211-2 capsule (~50 Euro) and build your own. There once was a DIY page for this mic somewhere on the net, but I can't find it anymore.
djQUAN
you might be talking about the DIY measurement mic in the ESP pages.
find it in www.sound.au.com
Nappylady
The behringer mic is good except for two things:
- it only goes up to ~19.5 khz
- it's NOISY
Other than that, it does an awesome job of capturing the exact sound of its placement; nothing more and nothing less.
audio-kraut
Have you ever tried it?
I use mine for measuring the various deq's, dcx's and ultracurves for over three years. I don't record with it - so, what's the problem?
bombardon73
19.5 khz is more then enough, and noise is not that important with frequencyresponse measurements. If the responce of the mic is flat between 200 and 15000hz it will be ok since measurements below 200 hz will be very inacurate (or you need to measure it openair). Just simulate the bassresponse and take that grafic and add it to the grafic you measured with the mic. This will give a more realistic result.
It's just that I need a tool to see if the crossover points are ok, and if the loudspeakers match with their sensitivities.
I do have some software now, so a nice Mic with a good price/performance ratio would do the trick. That Behringer sounds ok then, right?
zobsky
IIRC, .. www.speakerbuilder.net had a cheap diy measurement mic based on a panasonic capsule
bombardon73
Hmm, I'm gonna see if I can get my hands on one of those panasonic mic capsules! This looks very promissing.
bombardon73
Guys, check out this article. The Behringer seems to be pretty good and so is the panasonic!
http://www.ele.tut.fi/~artoko/audio...icrophones.html
rcavictim
I understand that the Behringer ECM8000 needs an external preamp and also phantom power. Does anyone use this mic plugged directly into the mic input of a standard computer soundcard? It is my understandung that there is phantom power voltage onthe mic input for such purcposes on a sound card. I recently obtained an Audigy card for the wide dynamic range and better frequency response it has for my computer testing suite. I'm still trying to get it configured.
pinkmouse
You will need a seperate preamp for the ECM, the "phantom power" that the card puts out is likely around 1.5V. Real phantom power is spec-ed at 48V, but can wander down to about 30V with no real problems.
Ron E
Sound Card mic bias is 5V, from 5V supply in the computer power supply., so it is perhaps +/- 0.3V.
My experience with panasonic capsules driven by the sound card (3 different ones) is that they are very noisy with quite a bit of hum, but that would depend on the sound card, I suppose.
I spent $50 and perhaps 15 hours all told shopping for the parts and building a wallin mic and preamp, just to have the output be noisy, distorted and barely useable. If I had an oscilloscope, I would have tried to fix it.....
I bought a Behringer ECM-3000 and UB-802 and 20' cord for $80 complete, and I never looked back. Worked the first time and every time since with no fiddling.....Trying to save $30 by DIY was a waste of $100's of dollars of my time.
Hertzschmerz
No, I meant http://www.friedman.purespace.de/Mic.htm . The author had used exactly the same Sennheiser capsule which I suggested. Unfortunately his site is dead. You can find the text parts from his page by copying the URL above into the "take me back" box at http://www.archive.org
[Behringer ECM 8000]
One problem with these microphones is that their real frequency response may deviate considerably from the plot in the Behringer specs. You can see an example at the already mentioned site http://www.ele.tut.fi/~artoko/audio...icrophones.html . No problem if you have access to a calibrated mic in order to record a correction file. Also no problem if you only need a tool for analyzing your crossovers.
I don't agree here. Nearfield measurements deliver accurate results in the lower frequency regions and are a useful instrument to examine bass alignment and low frequency cabinet resonances. But frequency response below 200 Hz is not a problem with most electret microphones. In contrast, I found major problems above 5 kHz (mostly sudden drop-offs) with cheap (fake?) Panasonic capsules.
rcavictim
RonE,
Your solution sounds practical. I agree about one's tiime being too valuable sometimes. I assume the UB-802 is not a German U-Boat. What is it please?
audio-kraut
quote:
One problem with these microphones is their real frequency response may deviate considerably from the plot in the Behringer specs
funny enough - the behringer microphone response is one of the better ones, and behringer includes a test sheet with each mike.
New massproduction since app. 1900 guarantees with included quality controls sufficiently small deviations of each produced item from the specifications of the lot.
With these curves it is possible to correct the measured frequency response of the object under test.
Just because something is cheap - and I gather from knowing my former countrymen - idoes n ot mean something is junk.
I refer here i.e. to some japanese produced items that in my opinion fulfill that role at 350k$ to a much greater extend. (wavec amps)
Hertzschmerz
This is new to me. Haven't seen such a sheet with the one i got.
Looks like you haven't been here for a while - "Geiz ist geil" is the current philosophy. :D
Zero Cool
There is an inexpensive Audix mic, the TR-40 that is about $145.00 US that last time i priced it, that is pretty good.
Personally i use a Earthworks M-30 that i purchased used for about $300.00
You can go to the www.siasoft.com website and take a look at all the mics there for use with the SMAART software.
Zero
bombardon73
Hertzschmerz, I somehow agree with you when you do low frequency measurements in nearfield (only a few centimeters).
But when you do the regular measurements (1meter distance) and use your living room the results will be inaccurate.
Wonder why Visaton has a measurement room of 7x7x7meters?
And if you see the loudspeaker measurements in Klang&Ton (german magazine) you'll notice that e.g. 8" bassspeakers have the same dip around 125hz. This is because of the room they measure in.
Thats why I would choose to simulate the bassresponse with some good software because bassresponse is more like a "mechanical" thing and is therefore very predictable when simulated.
As for the Mic, I think I'll buy me a Behringer. It seems it's more then worth the money!
audio-kraut
Pretty nigh on 25 years.
But - geiz ist geil kenne ich schon - apologies to the non germanic people here.
You are right - the sheet I got is the one published on their website. But I still maintain that under todays production conditions individual
deviations from the "lot" performance can and are held to a negligable minimum - otherwise one could sue behringer far false advertising;)
Anyway - for the purposes i use mine for it is quite sufficient - i.e. room response, delay and phase.
Ron E
quote:
Originally posted by rcavictim
RonE,
It is a Behringer preamp with phantom power. It is a good match for the Behringer mic and you can use it for karaoke parties if you get bored ;-)
"Geiz ist geil" kenne ich nicht. Trying to come up with a literal translation I get "greed is great" or "desire is luscious" or something like that. Ich weiss das der wort "geil", hat verschiedene meinungen, die haengen auf der zusammenhang. Geil was a replacement for "cool" or "super" or "Toll" when I was in Muenchen many years ago.... I only heard it used in the sense of the word "randy" as used by the English when I lived in Oesterreich, however....
audio-kraut
"geil" translates best as "horny", so "geiz ist geil" is a new attitude in germany. It sort of means that the cheaper one can get things short of fraud the more thrilling it is. Your translation hits it very well - greed is great. I think things are not that different in the states.
Interesting is - something for psychologists i guess - the connection between the sexual and the purchase of goods.
paologatto
Here:
http://purebits.com/miccomp.html
I made some comparison of the following microphones:
- BRUEL & KJAER 4190
- Sennheiser electret capsule KE-4
- Panasonic electret capsule WM-61B
It's interesting to see that the frequency responses of the different microphones are quite similar! Probably the B&K mic has better S/N ratio and better specifications, but this test proves that the inexpensive Panasonic WM-61B capsule is quite usable for loudspeaker measurements.
The KE-4 are slightly better than the Panasonic (I use them from long time) but they seem not more in production.
jackinnj
Decades agoSpeaker Builder had an article on called "Mitey Mike" -- they used an inexpensive Panasonic cartridge mounted in a thin tube -- Old Colony sells a kit linked here:
http://www.audioxpress.com/bksprods/kits/kd-4.htm
-- you can probably dig up the schematic and article for the original, there are also some knock-offs and improvements floating out there on the web.
Page generated in 0.065789937973022 seconds with 17 queries,
spending 0.00926709 doing MySQL queries and 0.05652285 doing PHP things.
Copyright ©1999-2009 diyAudio.com
