diyAudio.com diyAudio Forums Archive > Top > The Moving Image > LCD
Dell E153FP 15"? Will it work? - Click HERE for Original Thread
pjku79
has anyone tried to use a Dell E153FP 15" 15 LCD Flat Panel Monitor yet?
pjku79
anyone?
Rox
i heard the previous versions needed FFC extension but no idea about this one.
voovoov
quote:
I ripped a Dell E151FP 15" LCD, and I recieved a FFC extention cable (jumper) and connector from mouser.com today. Thus, I tried today and figured out a solder-free DIY extension FFC cable, and it worked very well. I don't think you should have problem with E153FP.
rustyb
There are no screws other than the ones holding the stand. How do I get the cover off? I got the monitor new and I don't want to destroy it. Any help or advice on using this lcd for a projector would really be appriciated!
doanster
quote:
I was wondering the same thing. Then I realized that you have to pry it off... start prying and you will see tabs between the two plastic cases. Then twist your screwdriver HARD for each tab. I ended up denting the plastic a little... but I guess no way around that :xeye: (I tried using paper wrapped around the screwdriver head with no luck)
doanster
So what kind of FFC cable do we need? There are too many on mouser.com :confused:
Page generated in 0.022223949432373 seconds with 17 queries,
spending 0.00640345 doing MySQL queries and 0.01582050 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
