diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
baffle Step - Click HERE for Original Thread
rgrayton
MarkMck, Why do you say this, "Now, I really do not want to get into baffle step correction. Such a discussion may be of limited value. "?
You kinda hint it does not exist under certain measurents. Care to elaborate?
BG
MarkMcK
BG,
I think you want to help me get myself into trouble here. Let me just say that there is a world of difference between the theory and what one needs to do in practice to compensate for enclosure/driver interactions. I have heard, even from proponents of baffle step correction, that the amount of correction the theory predicts and the amount needed in practice can vary. In addition, as detailed in a couple of my TB mods posted to this forum, I have found optimal transient response (and flat frequency response) requires correction in the opposite direction from that predicted by baffle step theory. When testing theories it is never a good thing to ignore falsifying experiments.
In addition, the original theory lumps what is a progressive series of acoustic events as if they all happened at once. Attempting to correct for something that can only happen late in any sort of transient event (and the music we listen to is full of such events) in the fashion suggested by baffle step theory, will overcorrect onset and reduce the transient quality of the sound.
I have also previously stated that if you simply want a sound you prefer and if something you do makes the sound more preferable to you, then no discussion is needed. I am interested in more than preference and so am involved in a different conversation. At times it may seem that preference conversations and opinion conversations overlap, but they really don't.
Good designing and good building,
Mark
rgrayton
Mark,
You said,"I think you want to help me get myself into trouble here."
Not really, you just hinted about something I have never heard stated, at least that way.
You referenced theory a lot in your response. For the sake of argument, let's forget that. Let's say I have a calibrated mic and an MLS measurement system, and a good measurement down to 200 HZ. The measurement shows a frequency content that includes a step and even a "hump", centered around 800 HZ (somewhat consistent with diffraction simulators I have used). The better transient response is the one where this "hump" is removed -- baffle step correction. Your response even said this:
"I have found optimal transient response (and flat frequency response)..."
So, by correcting baffle step, wouldn't I be producing a better transient response? Wouldn't a perfect transient response be one with infinite and flat frequency response? What am I missing?
I do not view this from the narrow view of preferred sound, only. Most of the time I relax the 2-4K region, or at least make that the lower point of my response -- that, I prefer.
BG
MarkMcK
BG,
By definition, by theory, baffle step occurs at some point after the transient (information change). Any electrical filtering will impact all of the signal. It cannot differentiate between onset or after onset.
From just a transient response consideration, when the problem is baffle step, and you try to apply an electrical filter approach you will always be overcorrecting onset.
Next, if the hump you are correcting is not baffle step but some vibration mode or resonance in the driver system, then it will impact both onset and decay. If this is the case, then a prefilter (notch filter) will correct the problem will little acoustic consequence.
Indeed, I am working on a loudspeaker design that has a hump at 800 Hz. The hump exists both in infinite baffle and conventional loudspeaker enclosure set ups. If the hump I measure in this system at 800 Hz were a baffle edge or baffle step problem, then it would not exist when mounted on a baffle where the pressure wave propogation over the baffle never reaches the edges before the sample window ends. As a result, I doubt that it is a product of baffle step or baffle edge diffraction.
I also said that the response variations measured in loudspeakers in the so called baffle step region are of complex origin. Part of that may or may not be baffle step. Blind following of a particular theory when application of that theory produces many falsifiying results is not recommended.
Mark
rgrayton
Mark,
Not sure I follow your argument, completely. A transient perfect/near perfect/better perfect... is the one, measured at my listening position with the flattest response (let's not include typical transient imperfect crossovers and limit this discussion to a single driver bandpass). So, if I measure at 2m and sit at the same location (let's disregard room, too), and measure 2 drivers in the same box, one with baffle step filter, one without. Wouldn't the one with, the flattest response measured, have a better transient response?
BG
MarkMcK
BG,
No. While frequency response can be derived from transient response, they are not one and the same thing. If there is a problem that occurs late after a transient event (such as that caused by an internal cabinet reflection or bounce off of some external object, or the edge of a baffle but within the test window), then correction of that by some alteration of the driver signal will "distort" the sound that proceeds away from the loudspeaker but occuring before the discontinuity of whatever cause.
Without doing my own testing, I cannot say, but I suspect that your 800 Hz bump is not a baffle problem if using a notch filter makes it test and sound more accurate (real, lifelike and so on).
The test of a theory is not how many postive predictions it makes but how many false predictions. Mere coincidence can account for agreement of theory predictions and measured results. Mere coincidence cannot account for when measured results contradict theory prediction.
Best,
Mark
Pan2
Hi... do you mind? :)
"No. While frequency response can be derived from transient response, they are not one and the same thing."
Sure they are, in a minimum phase system.
"If there is a problem that occurs late after a transient event (such as that caused by an internal cabinet reflection or bounce off of some external object, or the edge of a baffle but within the test window), then correction of that by some alteration of the driver signal will "distort" the sound that proceeds away from the loudspeaker but occuring before the discontinuity of whatever cause."
I think your mental model is wrong here.
A simple BSC made by a resistor and inductor in paralell with eachother and then in series with the driver will only "step in" after some time has elapsed from the beginning of the impulse. The delay of the energy in the inductor is set to match the point of BSC, so the problem you are afraid of does not exist.
You say that the filter will affect all frequencies, well more or less, but the high frequencies and the start of the impulse (same thing) will not care about the inductor but simply goes thrue the non-reactive resistor more or less.
That´s my mental model. :)
/Peter
MJK
Mark,
The last time I looked, if you are operating a speaker in the linear range of motion then the transient response (time domain) and the frequency response (frequency domain) are related by the Fourier transform. One can be calculated from the other, you only need one to describe the system. I have to admit that your statements seem pretty far out from an engineer's point of view. Could you provide some reference and further explanation for your theory? Is you Phd a technical degree or something else? I am afraid I am having a hard time acceptiong your position, maybe some further explanation and some references would help.
rgrayton
Mark,
I am not sure I follow your coincidence reference. The last time I checked, a theory was just that, a theory, no matter how many times it is reinforced by observation and or experiment -- that includes e=mc**2. It only takes one confirmation of a false result to disprove a theory.
BG
jdybnis
Correct me if I'm wrong. A thought experiment shows that a real driver is not a minimum phase system:
A real driver has harmonic distortion. If you input a sine wave to the driver, some of the acoustic output is in the form of the the fundemental and some is in the form of harmonics. The magnitude of the fundamental must be reduced because the energy to generate the harmonics must come from somehere, but the phase of the output at that frequency does not need to change because it has not been delayed.
rgrayton
I am not sure why you do not think a driver is not a considered minimum phase system (at least in the bandpass). From my understanding of a minimum phase system, the phase can be completely defined by the frequency response (excess phase due to time of flight from the UUT to the driver would need to be removed). If it were not essentially a minimum phase system, most of the available measurement and modeling software for this sport would be worthless and our systems would really suck as they rely heavily on a Hilbert Bode Transform, valid on minimum phase systems only.
BG
jdybnis
Read my post. Is my reasoning sound?
How much error is consequential? It's not an all or nothing situation.
tiroth
quote:
If what you say was true, then an equalizer could be used to correct all response anomalies caused by the room. Since these reflections cannot be corrected with a standard equalizer, they are manifestly not minimum phase.
GR. Koonce for one wrote in "Speaker Builder" 6/98 & 8/98 that diffraction is not minimum phase.
The strong implication would be that true BSC (phase as well as FR) would require FIR filters.
tiroth
http://www.soundfirst.com/EQ_Phase.html
quote:
When it comes to acoustic effects, these are much less likely to be significantly minimum phase since they often are due to the combination of multiple signals with delays due to the time it takes for sound to travel through air.
quote:
Now this is not to say that if you use an EQ to smooth out the response you measure with an RTA out in the room this will result in a smooth phase response as well. There are some things that just can't be fixed with an EQ. In particular, acoustic cancellations of portions of the amplitude response can't be equalized because the response is due to two or more signals arriving with different acoustic delays.
Why would we expect BSD reflections to be any different? Good insight MarkMck!
Pan2
There are no reflections below the baffle step.
You don´t experience reflection just becasue there is diffraction around the cabinet.
Room standing waves and delayed signals are not the same thing as bafflestep.
At least this is the way I see it :)
edit: but when I think about it I do believe I realize what you are after... and I remember I did think in those lines also some time ago... hmm.. food for thought.
/Peter
Pan2
First, I think it´s a mistake to believe that an internal bounce/reflection and room reflection is the same thing as baffle diffraction.
Also the high frequencies will not be affected... there is no reactive element involved in the high range since that is governed by the resistor so to speak.
What I can imagine would affect the total phase response is the low range where much of the signal (most) go thru the inductor which must have a delay involved.
IOW a speaker flush mounted in a wall, or mounted in a slim box could be different in that the box would have ever so slightly higher GD due to the extra inductance.
Thoughts?
/Peter
rgrayton
Obviously there must not be enough error to be consequential, maintaining my original point -- drivers are regarded by most to be minimum phase devices.
RG
russbryant
Hey RG what are you doing on this board?
Where did this thread originate? Seems like it started in the middle of the conversation.
Russ
jdybnis
Since that error is proportional to the amount of harmonic distortion in the driver we just might not be accounting for it. We already assume it's going to sound bad if a loudspeaker generates a large amount of harmonic distortion. So I wouldn't be suprised if we ignored the secondary effects of distortion throwing off computer simulations and models. I'm always wary of arguments that rely on assuming the status quo is optimal. Just because everybody does it some way doesn't mean it's right.
rgrayton
I am not sure what "right" means with regard to this subject. I would say that the present DIY models and modeling software do present an optimal solution and tool for most of us. This has been stated by many others, most likely much brighter and certainly more experienced and educated in the subject than me.
RG
Russ, This started out as a question to Mark McKenzie, but he seems to have abandoned the discussion.
tiroth
Can someone say authoritatively if BSD "reflections" are the same as room reflections in their mathematical interaction with the acoustic wave? If the mental model of the pressure wave hitting a discontinuity (edge of baffle) and "bouncing back" is true, than it would seem intuitive that in a non-round baffle, BSD reflection effects would occur with non-constant delay; e.g. non minimum phase.
Simply being able to say "yes" or "no" to this question would seem to resolve the matter.
:Popworm: That does seem to imply something interesting about round baffles, doesn't it?
Pan2
"If what you say was true, then an equalizer could be used to correct all response anomalies caused by the room."
The room is so complex, but looking at one room mode in isolation a regular EQ can counteract it IF the room mode is measured carefully and the EQ circuit is tailored to exactly mimik the Q of the mode.
Also a loudspeaker is a resonant device in itself, but still considered a minimum phase system. A in band resonance in a driver does not change the driver into a non minimum phase device..? It just change the Fr. and phase according to the Q of the resonance. With a simple LC or RCL circuit the response can be flat and corrected in phase as well, resulting in a transient perfect system as far as a driver can be that.
"The strong implication would be that true BSC (phase as well as FR) would require FIR filters."
I do not think so.
I think BSC brings back frequency response and phase to normal.
Lets take a step repsonse, the leading edge leaves the driver and travels towards listener and baffle edges. After 0.5ms or so the wave reach the edge and suddenly experience a pressure drop due to some energy diffract around the cabinet.
What we need is a circuit that is ready to push some extra current into the driver at this point in order to counteract the baffle step, since we can not have a transient perfect system that is not flat in Fr. The delay in the inductor is mathced in time to the time it takes the signal to reach the baffle edge.
If this simple baffle step circuit would change the system into a non minimum phase system, we would see a phase turn similar to a high order (non 1st order) crossover.
For now I´m convinced I was right from the beginning but I am ready to change my mind instantly if someone comes with a better idea. :)
/Peter
tiroth
Well Pan, I respect what you are saying, but I think you are oversimplifying in assuming the steady state. In a listening room 20' long with the listening position in the middle, the back wall reflection is arriving 20ms after the start of the tone. There is no way you can correct this reflection!
Now, you may well be right that BSD is a different beast than this. But I haven't seen an argument that persuades me yet.
It's an interesting discussion, I just have a feeling that someone like MarkMck already knows the answer.
Pan2
What the speaker do and what the room do are two separate things. Of course they affect eachother (i´m not stupid ;)) but you must realize that you do not only have the back wall reflection, you have lots of reflections that come and go, adds and subtracts.
You can´t blame a speaker or a BSC circuit for the mess that the room contributes with. Even though you´d maybe like to balance the amount of BSC against the contribution from the surfaces of the room.
"but I think you are oversimplifying in assuming the steady state"
Actually I did talk about transient behaviour, not steady state. Allthough as far as the speaker goes you will get the steady state from the impulse or step response (but not the other way around).
/Peter
planet10
Baffle diffraction -- of which Baffle Step is just a component -- is a continuum. At high frequencies, when the wave hits the discontinuity of the cabinet edge we get a reflection/reradiation of the wave. At low frequencies the wave does not even see the cabinet. At HF we have radiation into 2 pi steriradians, at LF 4 pi. In between is a continuum transitioning from one to the other.
In the last years my preference is to deal with the LF phenomenom by eliminating any baffle step from my boxes at the source -- a bi-pole (or alternatively a 0.5 speaker on the back if i'm not building with the FRs i prefer). As long as the box is symetrical back-to-front this perfectly compensates for Baffle Step (at the cost of an extra driver)
dave
Pan2
Dave,
sure it must be easier to get good results from a 0.5 driver mounted on the front? You´ll always end up with the delay from the back driver otherwise... no?
/Peter
planet10
Absolutly not... at the frequencies of concern the delay is close to insignificant and the 90 degree phase roll is hidden in the shadow of the box instead of mucking up the midtrange.
If you are really concerned make the box wider than it is deep.
dave
Pan2
I´ve never build such a design but what you say makes sense of course. I understand that there is no problem in low frequencies, but can you really get a smoth transition without ripples or a dip at/around the "step"?
/Peter
planet10
The beauty of the driver on the back is that -- as long as the cab is syymetrical back-to-front -- the bafflestep on the back driver perfectly fills in the baffle step on the front driver & visa-versa.... purely by the nature of the acoustical geometry of the system.
dave
Pan2
Have you accurately simulated that or measured outdoors/anechoic chamber?
Mirage seems to have problems with getting a 100% result if my memory serves me.
My mental model of this is that the enclosure needs to be thin as a credit card in order to make this work perfect... but on the other hand, what is perfection. :-)
I understand the basics and the function of this. It´s just that I have not spent much time on calculating exact what happens at what frequency so to speak.
/Peter
planet10
Nope... just a really good thot experiment and listening experience
They are multiway bipoles with a single bass driver if memory serves me right.
As long as the 2 bass drivers are within a half-wavelength below the baffle step they should be fine.
dave
russbryant
quote:
Since you were quoting Mark in the first post in this thread I figured that it must have came from another thread.
Russ
Svante
I saw this thread a bit late, but I'll share my view on the subject:
A driver and the diffraction produced at the edges is not a minimum-phase system, but as we shall see, it can be seen as one in some cases anyway.
In the simplest case with the circular baffle, the diffraction from all locations along the baffle edge will coincide and form a secondary impulse in the impulse response, and such a system is not minimum phase. The circular baffle results in a baffle step with large oscillations (in the frequency domain) due to the sharp secondary impulse.
This means that a circular baffle with the driver in the centre is a bad idea, in fact it is about the worst I can imagine. It is better to smear the secondary impulse from the edge by assuring that the driver-to-edge distance varies in different directions. Parts of the edge should be really close to the driver, other parts should be far away. In that way, a clever driver positioning can smear the secondary pulse in such a way that the amplitude and phase response becomes very close to that of a minimum phase system at low and mid frequencies. At high frequencies, the driver directivity reduces the radiation toward the edge, which makes the edge reflections and thus the minimum phase issue less important. All in all, this can make the resulting response close to a simple first order (one pole, one zero) system, and this can be compensated by means of a simple coil and resistor.
The error that remains is mostly small compared to other errors in the design, and can even be utilised to compensate other errors in some cases.
You can try this with my little "Edge" hack, and see that with a clever positioning of the driver, and with a simple compensating network, both phase and amplitude can become reasonably flat.
One final thing: The result of the diffraction at the edge is principally similar to a reflection at a wall in the sense that it produces an"echo" in the impulse response. However, the time that elapses between the first pulse and the reflection is typically larger in the wall reflection case due to a longer distance. The two cases are quite different in psychoacoustical terms. If the delay is short (as in the baffle diffraction case) the reflection merges psychoacoustically with the original sound and results in a colouration of the sound. In the wall case we will hear the reflection as reverberation or an echo if the delay is really long. The colouration can be compensated by a simple passive network, on the other hand the wall reflections probably need digital means to be compensated to inaudibility.
Pan2
I´d say Svante sums it up very nicely here. :)
/Peter
Page generated in 0.093962907791138 seconds with 17 queries,
spending 0.00632191 doing MySQL queries and 0.08764100 doing PHP things.
Copyright ©1999-2009 diyAudio.com
