diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Low-cost active crossover module for Hypex UcD amps - Click HERE for Original Thread
Al Garay
Is Hypex planning to release a low cost active crossover module that could be integrated with UcD amps for active 2-way or 3-way monitors?
To start, you could use the subwoofer crossover from the HS200 plate amps, 4th order/24db variable from 50-150Hz.
Dennis Murphy in Madisound is asking for an integrated solution, (active crossover and amps), for a 2-way with the crossover point between 2-3k Hz.
http://www.madisound.com/cgi-bin/di...cgi?read=325388
He put emphasis on simple, prefab active crossover that is integrated with the amps (like a stereo plate amp). So, the DCX2496 or Marchand would not do.
thanks,
Al
Page generated in 0.013832092285156 seconds with 17 queries,
spending 0.00569677 doing MySQL queries and 0.00813532 doing PHP things.
Copyright ©1999-2009 diyAudio.com
