| SLA Battery Charger - Click HERE for Original Thread |
| doomsweek |
Hello
How can I make a C/4 charger for my Panasonic Reachargeable Sealed Lead-Acid Battery ( LC-R06R2CH 6V,4.2Ah/20HR ). The battery's data sheet can be found
here
Constant Voltage Charge Method is recommended by Panasonic. Thanks. :D |
| apolon34 |
hi,
you can use a L200 which is a regulator with current limit included.
you should charge your battery at 1/10 of it's nominal current.
you have to set the L200 to output 6.9v when the current limit haven't been reached. |
