| edpgc |
I've looked and looked and I can't believe there isn't a simple solution to this. I'm looking for a device that will act as a USB audio device and provide a output at up to 24bit/96KHz, ideally in I2S but at the moment I'll take anything!
I understand there are ways to use a device from TI (such as the TAS1020B) and link it to a DAC, but I think this beyond my abilities due to it requiring custom firmware and software to drive it?
Ed |
| Wodgy |
TAS1020B and TUSB3200 will do the job but, as you point out, both require microcode. There aren't any other good USB options as far as I know.
Your best bet is to pick up a good low-cost USB interface and mod it. The discontinued M-Audio Sonica uses the TUSB3200 and is bit perfect in both Win2000 and XP with the correct WDM drivers (not the most recent ones). The M-Audio Transit is still in production, though slightly more costly, but it comes with real ASIO drivers (which are a huge plus and you likely wouldn't be able to write yourself without much additional effort). Both units have very small form factors. |
| edpgc |
| Any idea what this microcode looks like? Surely they provide examples, bot that I can find them! Good ideas though. Cheers |
| audio-kraut |
| What about soundblaster extegy? They connect to USB and convert to 24/96 output or am I wrong there? |
| edpgc |
| Yeah I'm really after just the components to build something rather different for myself. |
| MWP |
| quote: | Originally posted by edpgc
AFAIK unfortunatley there isnt an IC out yet that will do 96khz/24bit without some coding.
Needing to program the IC will also probably mean custom Windows/Linux drivers which is too much for most of us :( |
| ashok |
How good is the M-Audio Transit ?
It is not full duplex at 96khz/24 bits.
Full duplex up to 48Khz 24 bits(?) I think.
Any opinions on this unit ? Really small !
Thanks.
Ashok. |
| edpgc |
| Yeah, a 24/96 stream is about 5Mb/sec, with the 11Mb/sec bandwidth of USB 1 I doubt you could get and outgoing and incoming stream simultaneously at that rate. I'm also pretty sure the ADC won't be of good enough quality to warrant it anyway. |
