diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Sonic Impact Amplifier - Click HERE for Original Thread
Liver
Hello Gents, and welcome to my first post!
I recently bought the Sonic Impact class T amplifier and immediately opened it up. I am in the process of putting in into a nicer case and such, much like another post here.
I fired it up, and it does sound very nice.
My question is how could I go about hooking up a subwoofer with this amplifier.
The sub is self powered. Do I need a cross over of some type, and what would you recommend?
Liver
amt
If you have a self-powered sub, it should have a standard style plate amp in it that has provisions for inputting from an amp/receiver (push connectors) and then another set back out to your speakers. If not, you should consider buying a cheap plate amp from Part Express etc and using it with an existing sub or build one. Not sure by your post if you have a sub or need one.
amt
Liver
But I have seen two varieties. One is 15W and the other is 30W. The one I have is the 30W variety. I believe the 15W one comes with the speakers.
Liver
Page generated in 0.090918064117432 seconds with 16 queries,
spending 0.04254079 doing MySQL queries and 0.04837728 doing PHP things.
Copyright ©1999-2009 diyAudio.com
