| jlsem |
| quote: | | Can I buy or get exact drawings of Solo 206 cabinets ? |
I just e-mailed the guy and got a nice big file in return that printed out to about 3/4 size.
John |
| miku |
Mhmh, there is a message in Humble Homemade Hifi page that -> "Humble Homemade Hifi will be having a time-out from Friday 29-10-2004 until Monday 03-01-2005."
Also I can't find an e-mail address !
Can You help jlsem ? |
| jlsem |
| quote: | | Can You help jlsem ? |
I will look for the file. I may have it on a disk somewhere.
John |
| molekuul |
I have the drawings of the solo206 please leave an email and I will send them to you
I'm verry pleased with the sound. |
| miku |
Sent my email address to You.
Hope You received it !
Thank You ! |
| p_ete2003 |
Miku,
I also have the plans if you didn't get them from Molekuul.
At first I planned to build the Solo206, but ended up building the Fostex's recommended BL after all.
-Pete |
| p_ete2003 |
Hi all, I couldn't edit my previous reply. I don't have the Solo206 plans anymore, I've moved and the plans were on another computer and didn't remember to upload them to anywhere.
br,
Pete |
| Illusus |
Here is a slightly revised plan for the solo206, slightly cleaner look and smoother mouth...may not make much difference but I find it makes a little more sense.
Email me if you want the full size bitmap version. |
| Toropkin |
| quote: | Originally posted by Illusus
Illusus! Please, send me full size bitmap drawing. |
| MP3HiFi |
Hi all,
I am also interested in the plans.
Who could send them to me?
info@mp3hifi.de
Martin |
| p_ete2003 |
| Hi all, I don't have the drawings anymore. Someone who has, please inform here! |
| Illusus |
| I do have the solo206 plans...but they are on an old drive that crashed. I'm in the prcess of recovering the data, but it's taking some time frankensteining that thing together. I'll get them up on my web page as soon as I get them out. |
| squalor |
| I think the way you made the horn mouth looked better. Did it sound ok using the MDF ? Why did you get rid of it ? |
| Alain Dupont |
As I am working on it too...
I think I have the Solo 206 plan ; I wrote to the author, and he sent it to me.
Solo-206_CAD.PDF
PS: I am working on a slight modification ; going for 20 to 30 liters first chamber
to go lower down to 23/27 Hz at -3db
The other design is from Mr Valarcher {PV Acoustics} with 2 enclosures joined
by a bypass ... the second volume with a vent. The first 31 liters, second 214 liters FE206E going down to 23.5 Hz at -3db ; flat from 28Hz Up -0.5 db
Regards.
Alain. |
| Alain Dupont |
Solo X
Alain. |
| Illusus |
| quote: | Originally posted by squalor
Yes, I made the mouth look a lot like Alain's take on it (one more bend though). It did sound okay with mdf, a little muddy in the mid-bass compared to a multi-ply horn. I got rid of it to try something else, I can only hold on to a few designs at a time before my home gets too cluttered. I'll give horns a go once more when I move to a bigger home; I want to try something rather... well... huge.
BTW, if you (whomever), like Alain, eMail Tony for the plans he'll surely send you a hi-res copy. I'm not having much luck with or time for ressurecting my old HD. I'm being swamped with personal tragedies...I hope s*** comes in three's like they say, I can't bear any more for now. |
| JWFokker |
| quote: | Originally posted by Alain Dupont
Solo X
Alain. |
There's a lot of JPEG artifacting in the image. I can't make out any of the dimensions. |
| squalor |
| squalor |
Hope you don't mind Illusus. I had this pic of your Solo206 but couldn't attach it here so I posted it to FRF and linked. Definitely a better shaped mouth. What are you listening to now ?
I don't understand how Alain can enlarge the filter chamber, what's the science behind that ? Doesn't that unload the driver ? |
| Alain Dupont |
squalor,
I am using Martin J King software, plus an other source to go lower in frequency...
That is, be able to go down to 30 Hz with still 90/92 Db ; and to do so
I enlarge the volume of the chamber .
The goal is to reach about 30 liters and have a nice Freq response
flat from 28Hz Up at -0.5 db ; take a look at the curve attached.
Regards.
Alain. |
| Alain Dupont |
Squalor,
The curve... |
| squalor |
| I've been studying horns for about two months; everything I thought I knew just had a wrench thrown in it. I guess Onur and Klang were on to something. |
| Illusus |
Don't mind at all. I took that pic during my fit check. Later on I added some Baltic Birch braces in the mouth and replaced some of the MDF dividing panels with BB after finding some left-overs from another project.
At the moment, I'm listening to some big Basszilla-like speakers, FE-166ES-R in open baffle sitting on top of JBL E-140 in large-ish vented enclosures, Aurum Cantus G3 tweeters filling in the top. The ES-Rs are de-whizzered and phase plugged...wow, what a midrange. the whole thing is about to be bi-amped with active XOs replacing the passive stuff, i'll close off the vented bass bins and use a Linkwitz Transform Circuit with them. I toyed with LTCs for some time and find that, when executed properly, the bass is very balanced; tight like a dipole, dynamic as a horn and lower than vented. The whole thing is a work in slow progress.
I still have some horns to play with, but much smaller than the Solo, my own design but close to the Buschorn MKII, a lot longer anyway. sOund satisfying with some RatShack fe-103s. I drew them full scale and built at the same time so no plans, sorry. |
| doug_olitsky |
| here is the blue print for the Solo-206 as a .DWG and a .DXF file. It has 3 layers angles, dimensions, enclosure. |
| Jerry T. |
| quote: | Originally posted by doug_olitsky
Hey Doug,
There's just empty drawings in the zip file. :bawling:
(or am i doing something wrong) :xeye: |
| robertvalk |
| have you tried opening it with autocad? My pc wanted to but i still have to get my licence. |
| doug_olitsky |
I made a new zip file but its 163k+ and the system won't let me load it so however wants it just let me know and I'll send it directly to you.
The new file has updates on the acoustic stuffing
The .dxf and .dwg files are the same just different formats to suit your drawing package. There are 3 levels to the file
1) Drawing
2) Dimensions
3) Angles
HOWEVER--- when you open the file your software may choose an unsused level and will appear as a blank page. USE the level control feature of your software to see the levels I created.
Any questions feel free to drop a line :cool: |
| Jerry T. |
Got the drawings from Tony Gee at Humble Homemade HiFi
Here's what i've got so far.:smash: |
| Jerry T. |
| .....and more. :smash: |
| Kemmuri |
| can you send me the drawings ? i want to build these in a summer time |
| Jerry T. |
They are not mine to give, mail Tony Gee for the drawings.
You can contact him on his website
I just made minor (optical) modifications to it. :smash: |
| Kemmuri |
| he doesn't answer me :( |
| b-square |
| quote: | Originally posted by Kemmuri
be patient, he's doing it for free. |
| Jerry T. |
| That's probably because he's here today. :D |
| Geenius |
| Indeed I was! :) I have replied to several requests for Solo-206 plans, I presume one of them was yours, Kemmuri? |
| Kemmuri |
| yes there was, thanks a lot for drawings;) |
| Jerry T. |
| btw, almost finished |
| marioalfeu |
Hi, guys, I am nee here, and willing to make a Solo 206.
So, Doug, can you be kind and send me the dwg file you writed about?
Send it to malemos12 g m a i l
Thanks in advance.
Mário Lemos, wanting to become a d´yer. |
| Ricky Singh |
Hi Tony,
Im completely new to this whole thing. I have bought my first pair of fostex 206e and am itching to start building them. Would u be kind enough to send me the plans and any advice u may have when it comes to the construction.
Many thanks
Ricky |
| zgregz |
Hi!
I am actually a newbie here but I am very interested by the Solo 206.
I already bought a pair of Fe-206 and now looking for the solo cabinet drawings.
As I'm new here, I can't email directly to Tony Gee. So if someone could
send me these drawing, it would be very nice.
I let you the following adress : zgregz"at"gmail.com
Thanks for your help. |
| Jerry T. |
| Try it at his site. :mail: |
| gaetan8888 |
Hi
I just found two Dynaudio 17W-75 woofer, can I use them for that horn loudspeaker ?
Gaetan |
