diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Shelter cartridge loading - Click HERE for Original Thread
Frank McCrea
Hello,
I recently purchased a Shelter 501 and I'm about to start experimenting with cartridge loading.
The Shelter manual states the DC resistance at 12 ohms, and suggests the recommended load impedance as follows.
Step up trans within 20 ohms.
Head apmplifier within 100 ohms.
High gain EQ amplifier within 47K ohms.
I will be using a (47K ohm) Hagerman Cornet phonostage with some Lundahl LL9206 step up transformers set at the 1:10 ratio with 20db's of gain.
According to the specs above I could go down to within 20 ohms. I've done a bit of reading in the archives and it seems a lot of people are loading the 501's at around 100 ohms with various step up transformers.
Can some of you kind folks tell me where you are loading yours, and maybe comment on the differents in sound above and below the 100 ohm norm.
Thanks, Frank
ericpeters
I'm running it at 10 ohm (ortofon T20) and it sounds very nice (A lot better than my Sony SACD and also a lot better than my other cartridge AT-OC9ML )
Page generated in 0.016824007034302 seconds with 16 queries,
spending 0.00686622 doing MySQL queries and 0.00995779 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
