diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Alps TAPE!! heads - Click HERE for Original Thread
DragonMaster
should I try this
http://www3.alps.co.jp/cgi-bin/WebO...=2003&product=8
tape head, if I find where to buy one?
ashwick
Can't access the Alps PDF Catalog from the website.
Can you please attach the catalog along with your post?
oshifis
quote:
Originally posted by DragonMaster
should I try this
Do you build a tape recorder or just upgrading an existing one? I intended to build a tape recorder from this industrial set:
http://tube.fw.hu/store4.jpg
It is a very heavy cast iron chassis rig, with optical tape tension control, 8 speeds, 3 motors. Originally it recorded with FM modulation on 4 channels. I purchased Woelke heads (those used in Revox B78) and a Revox oscillator/bias PCB.
As it used to be, I abandoned the project due to lack of time...
Page generated in 0.017246007919312 seconds with 17 queries,
spending 0.00580716 doing MySQL queries and 0.01143885 doing PHP things.
Copyright ©1999-2009 diyAudio.com
