diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
FS: Anodized Alunimum Amp enclosure - Click HERE for Original Thread
jrsun
heat sink good enough for stereo (2-channel) Aleph-X 60W+ (60W@51 degree C)
dimension:W480mmxH200mmxD440mm inclduing 40mm phin on each side
weight: 13KG/29Lbs
1 available asking USD$200 + shipping
jrsun
BTW, the enclosure has never been used. The heat dissipation information is based on my friend's recent DIY Aleph-X 60-Watt amp on the same enclosure
jrsun
inside pic
jrsun
last pic
jrsun
how about $180 ?
tg3
Could you please post the dimensions and approximate weight?
jrsun
tg3,
the info you needed is in first message!
tg3
I can read. And write. Really. :blush:
fcel
May be you can't read metric system :)
analogdiy
all holes in this chasis are drilled in metrics standards. You might have hardtime finding the right screws to make those pre-drilled holes usable.
jrsun
analogdiy,
Not quite true, both homedepot and sears have stuffs in metric system.
BTW, 1 inch = 25.4mm
lgreen
check your mail.
Stabist
quote:
Some explanation please - 60W and 51°C - what??
lgreen
I think it means that if you make a 60W Aleph X the temperature of the heat sinks is 51 degrees C.
jrsun
quote:
Yes!
analogdiy
According to Diyzone, the chassis temperature will be around 60C when running 60Watt Aleph-X.
Page generated in 0.028448104858398 seconds with 17 queries,
spending 0.00729942 doing MySQL queries and 0.02114868 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
